Is this the correct ride height?? Pics inside...
Old Dec 27, 2004 | 12:58 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Hey all, I am really having some fun now that I got my digital camera for Christmas. I took a few pics and something isn't adding up here. Now, first off the car was a V6 originally but it has a 350 in it now with aluminum components ie heads, intake, water pump, etc. The front springs are the factory V6 units but even with all the weight up front it looks like it sits a little high. Tell me what you think......
Attached Thumbnails Is this the correct ride height?? Pics inside...-camarowheelgap1.jpg
Old Dec 27, 2004 | 12:59 PM
paulmoore's Avatar
And the rear...
Attached Thumbnails Is this the correct ride height?? Pics inside...-camarowheelgap2.jpg
Old Dec 27, 2004 | 02:19 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
yea, I'd lower it
Old Dec 27, 2004 | 02:21 PM
paulmoore's Avatar
Well, it will be getting an Eibach Pro Kit because that is the lowest that I can go with the Hooker Super Competition Long tube headers that I am running. I just wanted to know if that is the fatory ride height, or if I put the springs in incorrectly.
Old Dec 27, 2004 | 04:11 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
so you had the springs out hmmm. the rear seems ok but you should check the perch in the top of the isolation thing you may have had it move when installed. the fronts index on the bottom of the a arm there are two holes where the spring sits that the end of the spring should be in between. the front looks way to high to me the rear may be ok.
lowering springs are needed anyway. for v6 springs with a 350 i would expect it to sit lower than it does.
jeff
Old Dec 28, 2004 | 12:55 AM
paulmoore's Avatar
That's what I thought too. I think that I am going to end up getting the Spohn tubular lower A arms and change everything out at one time.
customblackbird
Aug 15, 2021 10:16 PM
92GTA
Apr 9, 2016 07:39 AM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
sailtexas186548
Aug 26, 2015 03:32 PM
Linson
Aug 21, 2015 02:12 PM
