shifter knob
Old Dec 28, 2004 | 05:40 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
shifter ****
How the hell do you get the factory t-5 shifter **** off. I thought it just unscrewed, but mine just spins. Any help would be great.
Old Dec 28, 2004 | 08:14 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
They are supposed to just unscrew. Mine doesn't, it won't budge even with a strap wrench on it.
Old Dec 28, 2004 | 08:44 AM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
pull the buton off
Old Dec 28, 2004 | 10:22 AM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
It takes a decent amount of spinning, but it does spin off.
Unless the inner plastc piece is loose from the outer **** and it's spinning in it. Shoud be able to see the plastic inster piece from the bottom.. see if it's spinning with the outer piece..
-Bud
Old Dec 28, 2004 | 11:58 AM
Engine: 4.0L
Originally posted by Burn0ut350
pull the buton off
There's no button on a T5 shifter ****.
Old Dec 28, 2004 | 12:37 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
in mine i had to put a pipe wrench in the shifter itself the first time as the whole assembly was spinning
Old Dec 28, 2004 | 04:16 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Thats because the handle (shaft) threads onto the shifter. And the **** threads onto the handle.
Night rider327
Feb 25, 2016 09:50 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
