4th gen tach gone crazy????
Old Jan 4, 2005 | 08:59 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
any one else have a tach movine very easily, jumpy? think its a bad cluster or? please help asap
Old Jan 5, 2005 | 12:20 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
did u just install it, or do you have the conversion setup done? curious because i think you need to get the dakator digital box to get the tach working right.mine jumps, switched to different cluster (for different reason) and it jumps, have a feeling they're all going to jump and be inaccurate until i get a converter box, probably the same for you.
Old Jan 5, 2005 | 12:24 PM
86IROCTHD's Avatar
Car: 88 Trans Am
i think the signal comes from the ecm on the 4th gen.... and its filtered..... so i will see what i can get done
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
