wind noise under dash pass side
Old Jan 10, 2005 | 01:36 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
ive had this wind noise about a year, tried finding it once too. gave up and put the dash back on.
now its getting worse and its hard to even hear talking at highway speeds. not alot of air coming through just really lloud air.
wondering if before i rip it apart in this -10 weather if anyone else had this prob. if i stuff somthing between the dash and the a pillar it goes away.
i may try baby powder with the dashpad off, and just do a blast down the highway but its messy.
Old Jan 10, 2005 | 04:10 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Could it be a bad seal between the windshield and the body?
Old Jan 10, 2005 | 04:19 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Try finding the missing grommet from the firewall. Look where wires or other items would be fed thru. Sounds like it's just missing that. It'd be easiest to find at night. Either put a light up under the dash and look thru the hood or vice versa.
Old Jan 10, 2005 | 06:20 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
use compressed air blow it under the hood along the seems where the ac box meets the firewall, then check all the rubber gromets and work from there.
Old Jan 10, 2005 | 09:12 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
usually its bottom of windshield being loose, comes unglued, happens all the time, ive had a few third gens like this, i had an 84 z 28 that the entire bottom of the w/s was loose and made the vin tag flap buzzing noise above about 25 or so mph
check for that
if so then for now you can go to local auto glass place and get tube of black urethane they use to glue them in and put it along bottom leading edge of the w/s
for now
til you have them re-bed the glass to the body w/s frame
good luck
Old Jan 10, 2005 | 09:24 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
check your floorboards.
Old Jan 10, 2005 | 09:56 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Also try checking the air vents for the A/c,heater.Along with all the suggestions above.
theshackle
Sep 17, 2020 08:26 AM
Street Lethal
Aug 14, 2015 08:25 PM
BlackBoulder
Aug 11, 2015 11:15 PM
wruiz
Aug 11, 2015 02:59 PM
3rdgenparts
Aug 5, 2015 11:57 PM
