strengthening headliner board
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
fiberglass stock factory headliner board, how to reinforce it on corners around seatbelt deal so the ends dont completely break off ?
thats all thats wrong with the headliner i pulled from this 87 for my 82, material is glued on great, no problems there,
what will stick to this fiberglass board, that napa or autozone or o reillys carry ?
tricks/tips ?
thanks
tricks/tips ?
thanks
Car: 92' B4C Camaro
Transmission: G-Force T5
This may sound like a read neck quote but it worked for me. Duck Tape, it held until I could get a good Plastic Headliner from Hawks. I sprayed 3M Adhesive on the same corners you're talking about, let sit until tacky, then applied the duck tape.
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
Originally posted by 92'Sleeper
This may sound like a read neck quote but it worked for me. Duck Tape, it held until I could a good Plastic Headliner from Hawks. I sprayed 3M Adhesive on the same corners you're talking about, let sit until tacky, then applied the duck tape.
Car: 82 Trans Am
Engine: Pro Flo Injected 355
Transmission: BW Super T10 4 speed
Axle/Gears: Ford 9"/3.50
i just used the spray adhesive available at local hardware stores and some drywall repair mesh tape. it is holding pretty well...
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The right way to do it is to get some fiberglass strips and some fiberglass resin. This stuff is available at any auto parts stores and even Wal Mart. Put some resin over the headliner, and then lay resin soaked fiberglass strips in the area. It'll be as hard as a rock when it dries.
A half assed way to do it that actually works suprisingly well is to buy some burlap, and spray the hell out of it with 3M spray adhesive until it's wet. Lay it into place and wait for it to dry.
Engine: 4.3L Z TBI
interesting,,
yeah i definitely gotta do one of these to the headliner i pulled form the 87 maro, for the 82 t/a
its all there and fabric good but damn corners coming apart, especialyl the rear ones aroiund the ceiling belt mounts.,..
its crap,
thnaks fr any further info, tips, suggestions
its crap,
Linson
Oct 1, 2015 09:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
92, board, camaro, car, cars, cheap, fiberglass, good, headliner, material, reinforce, resin, strangthen, strengthen, strengthening
