interior door bushings? wtf
Old Jan 20, 2005 | 09:37 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
When I was swapping out my window motors, I noticed a round rubber bushing (broken) laying in the bottom of the door. Passenger side was the same too. Couldnt figure out what it came off of. Looks about the size of one of our upper shock bushings.
Anyone able to shed some light for me?
Old Jan 20, 2005 | 09:41 PM
jay92,85,79's Avatar
Car: 85z28,
I think thats for when the window goes down the glass sits on there. In the middle of the door u will see a braket it goes on top of that. If we are talking about the same thing.
Old Jan 21, 2005 | 12:21 PM
could be.....what purpose does it serve? Maybe thats why my windows rattle so much when i shut the door now they are blown.
Old Jan 21, 2005 | 12:41 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Yup, the rivet feeds through that to cushion it from the glass...probably a rubber or teflon coated washer down in there as well
Old Jan 21, 2005 | 03:07 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link for info:
https://www.thirdgen.org/techbb2/sho...hreadid=124084
JamesC
Old Jan 22, 2005 | 03:49 PM
James I read your article a while back and recently tried searching for it but could not find it. Thanks for the link!!
I have not taken my door panels off since i did my window motors. I also discoverd that by using rubber washers when riveting the motors in place makes a diff with rattles.
I'm couldnt see by the diagrams incl in your post about where that pesky rubber bump stop is supposed to be.
Is it supposed to sit toward the inside of the glass or the outside? And where exactly is the bracket that holds it?
Thanks so much for your help
Old Jan 22, 2005 | 04:37 PM
JamesC's Avatar
The bump stops are positioned at the bottom (underneath side) of the window channel itself at both ends. The window rests on the stops when the window is down. With the door panels off, you should be able to see the old rivets, which would still be in place even though the stop is gone. I used a Dremel to cut the rivets off, then simply used a bolt and nut to secure new stops.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
1nastygta
Aug 8, 2015 07:38 PM
