5 Point Harness Installs
Old Feb 5, 2005 | 03:01 PM
Rage13's Avatar
Car: 89 Firebird
Hey guys I'm getting ready to order some kirkey seats (47900) and some Simpson or Impact camlock 5 point harnesses. But I'm not sure witch harness to get or where exactly it should be mounted.. So whos got some pics and info?
Also I have an S&W 8 point roll bar I could mount it to.
Old Feb 5, 2005 | 03:18 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I was able to reuse the factory lap belt holes for the new waist belt on the harness. You need to attach the Y or H harness (over the shoulder part) to the bar welded to your hoop. You'll have to make some plate and drill a hole in the floor board for the submarine belt.
I was able to notch out the factory cover where the factory retrac thingey is so I could leave it in place, but still allowed the new harness to bolt into it.
old pic, but you get the idea
Old Feb 5, 2005 | 04:08 PM
Rage13's Avatar
Car: 89 Firebird
cool, good info. but i'm not sure what your saying you notched out.. no pic
Old Feb 5, 2005 | 07:29 PM
IHI's Avatar
IHI
Yeah the pic attachement is'nt working right now on the board so my pic did'nt do much good.
The retractor part on the outside of the seat that holds the belt has a plastic cover-one side rests on the sill and the other side goes down and sits agasint the carpet. Your harness lap belt will have a flat peice of steel that gets bolted to the car. There is no provision on the side of the plastic retractor cover to allow that flat peice of steel to go through so you can bolt it to the car. Hence the need to slot/notch it out so you can bolt it too the car and still keep the factory retractor cover installed for astetics-other wise there is a big void in the sill cover that the retractor cover hides
Old Feb 5, 2005 | 08:36 PM
Rage13's Avatar
Car: 89 Firebird
now i know what your talking about. the interior is out of my car so it won't make much of a difference..
what belts are you running in your car? i'm thinking i'll go with a Simpson camlock p/n 29112, says its a 55" wrap around
Old Feb 5, 2005 | 10:42 PM
IHI's Avatar
IHI
I'm just running RCI Y-type with a latch. I have to replace these every 2 years, so spending twice the cash on a maditory replacible item is just not practical. Serves the same purpose just not as "cool". If I did not race and just wanted the cool look, I would then spend the $140, by $70 every 2 is bad enough.
Old Feb 23, 2006 | 07:24 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
anyone got any pics with a wraparound style mounting, I think i know what to do, just want to be sure.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86IROC112
Aug 17, 2015 07:57 PM
