Fixing aero spoiler with fiberglass?????????
Old Feb 17, 2005 | 02:35 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
Hello,
My girl friend is looking into getting an 87 TA and the spoiler is as you all know warped looking and the paint is all chipped off it. Now this car may be bought for around $1000. So right away its not worth sinking alot of money into like a new glass wing and then a perfessional paint job. Its not ganna happen even tho it would be nice.
Heres what i was thinking.... what is if use the factory cr@py wing as a mold and layer fiberglass resin over it and maybe a layer of matting or 2. If i use enoght resin then some sort of body filler top coat to sand out farly level...then paint. Does anyone think this will work?? I dont think ill have any seperation problems between the wing and glass because the glass will wrap right around underneath holding itself on.
When I did a search and the only person I found who I seen may have tryed it with fiberglass was a guy named "bnoon". I have PMed him but still no reply. Has any one else tryed puting fiberglass over the whole wing. I have used fiberglass before and I think it should work.
Old Feb 17, 2005 | 02:41 PM
tilstad's Avatar
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
Three separate painters Ive talked to has said it's not impossible to do. They all talked about using some sort of "plastic" filler, meant for bumpers I suppose. I have seen one locally who have painted it successfully, don't know how long it's been since he did it though.
It seems not impossible to do, only might not hold up in the long run. For others 3-4 years is enough.. and perhaps it will last longer... who knows.
Old Feb 17, 2005 | 04:04 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Which wing are we talking about???
Is it the T-bar wing, or the wrap-around GTA style??
Either one is VERY repairable, as long as there are no large chunks missing, you're golden.
Old Feb 17, 2005 | 04:10 PM
tilstad's Avatar
I think he's talking about the aerowing, correct me if I'm wrong, and I guess he's talking about the fine hairline cracks they all get.
On mine most of the cracks where around the area where you put your hand when closing the hatch. So I guess if you close it without hands, it'll hold up fine
Old Feb 17, 2005 | 04:19 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I say remove it, fill the holes, and re-paint the hatch panel. That thing is 30lbs Mine was real ugly looking and the leading wrap-around parts would flap around on the highway
Old Feb 17, 2005 | 05:24 PM
KEVIN G.'s Avatar
Engine: 305 CARBED
I thought so, but wanted to be clear...
Still repairable. A LOT, AND I MEAN, A LOT, of people are under the assumption that you can paint these just like any other panel and they'll hold up....
It all goes back to what I've been saying for a long time now USE FLEX AGENT PEOPLE!!!!!!!!!!!!!!!!!!!!!!!!
You need to get all that old paint off, prep it with a plastic parts cleaner... use an adhesion promoter for plastics, prime with a two part primer (WITH FLEX), sand, paint and clear(WITH FLEX!)
OH, and another thing...IT'S NOT A HANDLE!!!!!!!!!!!!
close the lid with your hand lightly on the STEEL portion of the outer edge...
How many times have we seen the T-bar spoiler bite in to the lid because of somebody using it to open and close??
Old Feb 23, 2005 | 06:45 AM
Car: '81 Trans Am
Engine: 6.6L
ok thanks looks like flex and adihsion is the key...... because taking it off isnt an option....my gf actually bought the car last week i think she has pics on cardomain ill post a link of the condition of the wing as soon as i know her address.
Old Feb 25, 2005 | 02:03 PM
budweiserbeauty's Avatar
Car: 1988 Formula
Engine: 5.0
Hey people...
Here's my car domain site...
Page 2 has some exterior shots that shows the pics of my wing and the shape its in
WARNING: This site may cause nausea due to large amounts of paint chips and rust! Enter At Your Own Risk!
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
