Anyone swap in firebird door panels to a camaro
Old Feb 20, 2005 | 02:16 AM
Spdfrk1990's Avatar
I want to swap in the firebird door panels since the lock area plastic is smaller has anyone done this and im not talking about the GTA panels. If so will they bolts right on just curious what all i will need.
Old Feb 20, 2005 | 06:20 PM
topless 88's Avatar
Car: 88 iroc convert/87 formula/91 Z28
Engine: tpi 305/305 carb/305 tpi
Transmission: 700R4x3
Axle/Gears: 3:73/323/273
It just bolts into place. I did this swap last year. The only problem you will have is if you have power mirrors. There is no place for them in the bird panels. I got the wires from a bird and ran them to the console. If you have a power hatch release if can be a problem too. I put the switch below that and it works fine. You can put the camaro switch in the stock location but it doesn't look right there.
Old Feb 21, 2005 | 12:16 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You may also want to use the T/a arm rest.Since they are slightly different at the top.Where they screw to the door frame.That & the lock bezel are the items you want to watch for.Panel itself will go on the same way as the original.
Old Feb 21, 2005 | 08:42 PM
Spdfrk1990's Avatar
Thats cool i like the firebird panels much better.
Old Feb 21, 2005 | 08:49 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Werd
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
