headliner experts
Old Mar 1, 2005 | 07:48 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
headliner experts
i removed the old fabric and foam from my board and there are a couple spots that are deeper then the rest of the surface on the fabric side, will the fabric cover this or do i have to fill it somehow, and if i fill it will the adhesive stick to that part?
Old Mar 1, 2005 | 10:19 PM
89rs_1's Avatar
Car: 89 rs camaro and 01 mustang
Engine: 2.8 v-6 and 3.8 v-6
Transmission: auto and 5 spd
head liner problem
first off how deep are the spots? if not very deep u can spray the board with adhesive then use masking tape on the spots then do not reglue over the tape then it will not show at all hope this helps
Old Mar 2, 2005 | 05:33 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
the spots are not that deep, if i use tape how is the fabric supposed to adhere over that spot without adhesive?
Old Mar 2, 2005 | 10:22 AM
89rs_1's Avatar
headliner question
it doesnt adhere where the tape is but adheres every where else. it doesnt have to adhere to every lil inch as long as it is pulled taught. u are using headliner material right? it has about 1/4 in foam backing? this is the way ive alwys done them in my shop. any more questions let me know
Old Mar 2, 2005 | 10:52 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
yeah brand new headliner material with 1/4" foam back
Old Mar 2, 2005 | 11:27 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You could always put some foam backing material in there to fill it. The way I do mine is to use 3/8 inch padding glued to the repaired headliner, and then stretch vinyl over it, tight, then staple into the fiberglass.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
djmarch
Oct 2, 2015 10:41 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
blackbmagic
Sep 8, 2015 10:36 PM
