Vac Gauges
Old Mar 13, 2005 | 04:39 PM
theshmo891's Avatar
Vac Gauges
I was reading one of the things on gas mileage, and someone said to get a vac gauge, that said like "good and bad" i looked on summit for vac gauges and all i found were boost gauges kuz im guessing they run of vac pressure, can anyone help me here? or explain to me what it is
Old Mar 13, 2005 | 05:00 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Goto www.jegs.com search for 'Vacuum Gauge " You'll find tons of them.
Old Mar 13, 2005 | 05:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
During the 70s when everyone started to get worried about mileage, you could get vacuum gauges that said your mileage was "good" when vacuum was high, and "bad" when vacuum was low. It's really just a source of feedback so you can train yourself not to put your foot so far into it all the time.
I don't know if you could still get a gauge marked that way today, but it doesn't matter, a normal vacuum gauge marked in inHg does the same thing and is probably more useful if anything.
Old Mar 14, 2005 | 02:53 AM
Night rider327's Avatar
Car: 1988 Camaro
You can get gauges that tells vac w/o boost pressure. I have an auto meter sport comp 2-5/8" vac gauge.
If you get one that reads in inchs like the auto meter. The hand will sit to the far right on 0. With car ideling it will be somewhere between 10 and 18 based on engine, cam, etc
When driving norm., steady throttle, etc it will read in the 20's
Any time you floor the throttle it will drop to 0 then start picking back up
The idea of saving fuel with the gauge is.. Drive so you keep the highest vac reading. As long as the hand is over to the center or left your not useing as much fuel. When that hand is over to the right, your useing more fuel
OH BTW.. I think I seen one in the JCW catalog that was marked for good gas mileage and bad gas mileage www.JCW.com
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Luigytico09
Oct 1, 2015 08:46 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
