floor board rust por-15 experts
Old Mar 16, 2005 | 03:31 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i started to tear up my carpet, and i found some rust, it doesnt look too bad, how should i go about repairing it? i was thinking i could use por-15 on it, it looks like the padding is a little wet, must have a little leak somewhere.
can i just get like a quart of that por-15 rust prevent and brush it on?
Old Mar 16, 2005 | 06:58 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
It already looks to the point where I can see a hole? Can you push through it with a screwdriver?
id cut out the rust and weld in new patch pannels. Then POR15 the complete int.
Old Mar 16, 2005 | 07:52 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
i dont see any holes yet, it's rusted on the seam, i gotta get the whole carpet out and look at it further
Old Mar 18, 2005 | 02:25 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I did the por15 thing to mine. Stripped the floor to bare metal Didn't have nearly as bad rust as yours though. But heres what I wrote about it in another post .
"I used POR15 over rust, paint, and bare metal. Both with and without metal ready on each. Followed direction for prep to a T. Didn't turn out well to any of them. (Seems though as it it stcuk to the painted area better? where I had overlapped) Its not peeling or anything but it scrtaches way too easily. Just be sure to use a water based degreaser.
According to POR, it will stick to paint but wont offer the rust protection as it would over prepped bare metal or rust.
also might want to try rust bullet. Haven't really heard any negeative about them. Like POR15, but they claim less prep needed."
As far as looks it turned out great, but whether it will protect good enough?????
Edit: a quart is plenty for the minimum 2 coats they recommend.
Attached Thumbnails floor board rust por-15 experts-c-windows-desktop-fff.jpg
djmarch
Oct 2, 2015 10:41 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Linson
Oct 1, 2015 09:50 PM
zman1969
Oct 1, 2015 11:09 AM
