quick steering wheel question
Old Mar 19, 2005 | 02:27 AM
EatFordShtDodge's Avatar
Car: C230 Kompressor
Engine: 2.3L Supercharged I-4
Transmission: 5-Spd Tiptronic
really quick, will a 91 steering wheel hook straight up to my 84?
thanks
need to know asap so i can buy the guys wheel or not
Old Mar 19, 2005 | 12:04 PM
F-BirdBauman's Avatar
Car: 1987 Firebird
Engine: D.Remmington 415 Small Block
Axle/Gears: 4.10
Yes it should as long as theres no damaged parts. It should be a direct bolt up
Old Mar 19, 2005 | 03:08 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
If the 91 uses an airbag wont that cause a problem with the 84 column?
Old Mar 19, 2005 | 03:28 PM
well i wasnt planning on setting up the airbag, i hate the older steering wheels, they dont feel as good as the 90+ i could go aftermarket but i miss the wheel i had in my RS
Old Mar 20, 2005 | 11:40 AM
Car: 1987 Firebird
Axle/Gears: 4.10
If you want the airbag to operate you will have to use the bcm and the collumn out of the newer car but if not you can bolt the new wheel up dirdctly, it's up to you.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
