headlight motor-do years make a difference?
Old Mar 20, 2005 | 09:41 AM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
my passenger side motor went today and im on the hunt for a new or used one from a junkyard or auto store..so far advance said its a dealer item and the junk yards ive been to so far when i was lookin for a module said we dont have 91s...so..i was wondering if older years or maybe newer years will work...thanks again..
Old Mar 20, 2005 | 01:56 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
1982-86 Firebird use a 3 wire motor that isn't compatible with yours. You'll need a 1987-92 Firebird headlight actuator motor. Does your motor spin, yet the headlight door fails to raise? If so, then you don't NEED to replace the headlight actuation motor. The problem can easily be cured using the TDS p/n 207280 headlight repair kit or the TDS p/n 209280 Deluxe Headlight Repair Kit. Hers's what has happened: There are 3 solid gel bushings inside the large nylon gear that is driven by the worm-drive of the motor. These bushings transfer the load from the gear to a 3-lobe cast hub that is part of the actuator shaft. These inserts harden and crumble with age, breaking down to roughly a spoonful of crumbs. At this point the gear will no longer turn the hub to raise and lower the headlight assembly. Instead hub will just free wheel on the gear. Replace the bushings with the solid Delrin bushings from my kits and your headlight motors will work better than new.
Lon Salgren
Top-Down Solutions
Old Mar 20, 2005 | 02:31 PM
Car: 1985 iroc-z
yeah...thats not what i need. my motor burned up. its black. but at least i know now i can get something from 87-92. its hard finding stuff for a 91
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Grant2k
Jul 10, 2018 04:01 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
