Check out the new gauge faces!
Old May 26, 2005 | 10:50 PM
  #101
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
that tape is cheesy.. I was thinking along the lines of the double stick tape being a duplicate of the gauge itself in one large piece already bonded to the back of the new face... perhaps with the back part you remove to get to the sticky stuff broken into four pie shapes so you can remove them after you've got the new face over the needle. However thats not a great option, it is still 'tape'.
How thick is this gauge face... like the thickness of a DVD sleeve cover? (The part over the paper insert)?? I still think a perimiter mounting method would be best, just don't know how to accomplish that. Is they any way tabs can be wrapped around the stock gauge perimiter? I don't have my guages here so I can't look at them.. both my car and 2nd gauges are at the shop! I'll keep brainstorming...
Old May 28, 2005 | 11:15 AM
  #102
Gr89RS's Avatar
Car: '02 Z06
I currently havethe 115 MPH speedo, if i had one of these printed as a 145 MPH, what would i have to do to make the gauge read accurately??
Old May 28, 2005 | 11:25 AM
  #103
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Yea, thats a good question. I have the 185 kph spedo right now but I would like the gauges to go to 240. Would I have to buy the 240 kph spedo to make it read properly.
Old May 28, 2005 | 12:47 PM
  #104
Brisk's Avatar
the internal windings of the speedo's are different from a 115mph to a 145mph.. or any speedo for that matter( like kmh). You would need to purchase a speedo that can give you a higher reading, there is no way for 'us' to change the workings of the speedo unless your a instrument calibration technician with the proper equipment and such...
Old May 28, 2005 | 07:09 PM
  #105
Gr89RS's Avatar
Car: '02 Z06
So would that be something a shop would do??
Old May 28, 2005 | 10:22 PM
  #106
Brisk's Avatar
it would be much cheaper and easier for you to buy a replacement set of gauges that goto 145mph.. try the classifides here on TGO or ebay, local auto recyclers
Old Jul 6, 2005 | 03:40 PM
  #107
Gr89RS's Avatar
Car: '02 Z06
So how are they holding up Abubaca??
Old Jul 6, 2005 | 03:57 PM
  #108
Brisk's Avatar
either they fell apart, or he's looking at becoming a wholesaler and mass producing them
Old Jul 6, 2005 | 08:54 PM
  #109
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
On my Firebird I cheated and had a custom set made by Scott at www.customgaugefaces.com. He let me pick and choose the way I wanted them to look, so I changed a few things, like adding a few hash marks and making the 145mph Iroc speedo into a 150mph speedo and changing the tach reading from RPMx100 to RPMx1000 (so the numbers around the tach read 1 2 3 4 5... instead of 10 20 30 40 50...)
Here's what I ended up with:
Old Jul 7, 2005 | 01:18 AM
  #110
Apok's Avatar
Car: 1986 Iroc-Z
Engine: 305 Tpi
those are beautiful, I'm in if you start producing them!
Old Jul 7, 2005 | 03:13 AM
  #111
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Abubaca, don't laugh, but is there any chance you'd consider the 85 MPH speedo too? Oh, for a 'Bird that is
Wonderful gauges! Try not to abuse you new found power as shop manager MUHAHAHAHA!. The 3rdGen community needs guys like you working in places like that.
Mark.
Old Sep 12, 2005 | 07:40 PM
  #112
Abubaca's Avatar
Update:
Guys I'm stumped here. The faces are holding up just fine, and I have pretty much all the kinks worked out except one:
I CAN'T FIND A 5/8" PUNCH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If you guys remember, I needed to put the actual face/print (which is basically just a sticker) on something to give it some rigidity. I decided to use an acetate sheet which seemed to work very well. Rigid, yet thin and flimsy enough to be worked past the needles without removing them. The problem is that I had trouble cutting all the little holes. I used an exacto knife before I used the acetate which was no problem. On the set I'm currently using (with acetate) the hand cut circles aren't perfect, and they took FOREVER to cut to what I would barely consider acceptable.
Enter the hobby of scrapbooking.
I have punches for all the holes needed except for a 5/8" punch for the center hole in the tach and speedo. The THIRD punch arrived today, and it won't work either. The main problem is that they don't reach far enough into the face. Basically I can't reach the middle of the face to punch the circle!
This is driving me nuts. Everything else is ready. I know some of you will say that I should just do my best with a knife, but trust me, even if I could do it perfectly, it would take forever, and I need some sort of mediocre assembly line here. They're all assembled by hand, short of the printing, so I need the help where I can get it!
first of all, can you guys picture what my problem is? Did I explain it sufficiently?
...and my next question:
DO ANY OF YOU HAVE IDEAS????????????
Old Sep 12, 2005 | 07:43 PM
  #113
Abubaca's Avatar
....oh, and I had been working on some backlit faces, but this latest problem has been a real pain. Such a simple problem that I can't seem to solve.
....anyhow, if I can do backlit material, I can do just about any car out there!!!
...but let's not get ahead of ourselves just yet.
Old Sep 12, 2005 | 08:06 PM
  #114
Brock's91RS's Avatar
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
Would something like this work?
http://www1.mscdirect.com/CGI/N2DRVSH?PMSECT=1917
We use these at work to make some shims,they punch .010 plastic shim stock nicely
Kind of pricey tho
Hope that helps
Steve
Old Sep 12, 2005 | 08:19 PM
  #115
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
Most leather shops (The ones that sell leather and supplys, and kits - Like Tandy) have hand held punches of different sizes - may be just what you are looking for...Ed.
Old Sep 12, 2005 | 08:50 PM
  #116
Scheister's Avatar
Car: 85 IROC
OMG those are awsome! i want! good job
Old Sep 12, 2005 | 08:59 PM
  #117
Brisk's Avatar
Abubaca - how about making a punch, literally. Take a piece of round steel stock and grind/mould the end to your desired size (5/8") Then use this piece of steel as a punch, put the desired size down on the face, and hit the other end with a hammer and 'punch' the center out.
You should be able to put an 'edge' on the side with the desired size and it may do the trick. At least, it would make a good impression/indentation and should make it easier to cut out? Hopefully you get what I'm trying to say..
Good luck.. I'll keep racking my brain for more ideas.
Old Sep 12, 2005 | 09:23 PM
  #118
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Originally posted by Abubaca
Update:.
This may be quite far fetched, but could you take one of the punches and have someone cut the arms and re-weld extensions? Even if the handle couldn't overcome the leverage you could tap it with a hammer for now until you could find something better. If this is possible you could have a jig on the arm set up for the exact distance every time.
Old Sep 12, 2005 | 10:08 PM
  #119
Abubaca's Avatar
Well, some of you have started thinking along the same lines as me. An actual punch that would be done by hand as opposed to some scrapbook tool.
....I'm gonna keep messin' with it.
Old Sep 12, 2005 | 11:24 PM
  #120
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
If you ever wanted to remove these & return the gauges to stock.Would the stock faces be ruined(residue,etc)?
Old Sep 13, 2005 | 06:54 PM
  #121
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
OH yeah !!
You've started a monster here... I want in too !!
Get 'er done !!
Old Sep 15, 2005 | 11:28 PM
  #122
Abubaca's Avatar
As far as returning to stock...well....it depends on how you stick 'em. I'd probably provide tabs of double sided tape. Would it leave residue? Probably. Could you get it off? Probably, but I wouldn't make any guarantee.
Old Sep 16, 2005 | 12:51 AM
  #123
Scorpner's Avatar
Engine: V6, V8
Goo gone works good for stuff like that.
Old Sep 16, 2005 | 12:34 PM
  #124
ZROC86's Avatar
Car: 1999 Trans Am WS6
Transmission: A4
Thats tight man! Good Job. I'm down. Keep up the awesome work!
Old Sep 16, 2005 | 05:59 PM
  #125
Car: 84Z & Porsche
When all of ther bugs are ironed out I would definately be in for a custom set...Keep up the good work. ~Ed~
Old Sep 21, 2005 | 08:22 PM
  #126
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
Wow. Those look really good.
Old Sep 24, 2005 | 06:05 PM
  #127
XJOSHX's Avatar
Car: 1988 Iroc-Z
If you want to sell me some PM me
Old Sep 24, 2005 | 06:50 PM
  #128
Abubaca's Avatar
Well, I'm still a little frustrated on this one. so close, yet so far. I'm looking into having the actual acetate faces made, and then I'd apply the graphic to the acetate.
....I'm also deconstructing the punch to see if there's anyway to rig it for my purposes. Having them made may very well be cost prohibitive.
Old Sep 25, 2005 | 09:58 PM
  #129
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
I work at a car dealership and occasionally we put on spoilers for new car deliveries. To mark where the holes go, we use a punch (essentially a metal rod w/a pointy end) that makes an indentation in the sheet metal to use as a centerpoint for drilling the hole. If you had a drill (handheld or bench may be better), that wouldn't have any problem getting through the acetate, and the holes would be perfectly round.
Just a different way to skin the same cat.
Old Sep 26, 2005 | 08:12 PM
  #130
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
i would definantly be up for a set too. keep up the good work.
Old Sep 27, 2005 | 09:32 AM
  #131
Abubaca's Avatar
The drill idea is a good one, but it just isn't clean enough. Kinda like a bull in a china shop so to speak.
It falls under the category of what would work to get the job done, but not well enough to actually sell to people.
Got pricing yesterday on having the acetate cut. TOO much money, PLUS, I'd have to buy 'em all up front. It's a no go on that idea.
Old Sep 27, 2005 | 09:55 AM
  #132
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
ya i want some too!!! you said you can make then for any application right? i would really like some sweet gauge faces for my '91.
post your email up here or email me at studcamaro91@yahoo.com please and thank you
Old Sep 28, 2005 | 07:25 AM
  #133
85transamdriver's Avatar
Car: 85 trans am
Transmission: automatic
I have had absolutely no luck finding new gauges that look good for my 85 or 86 t/a ans this would be awesome. i want eveything to be either blue or orange at night in the dash
Old Sep 29, 2005 | 12:06 AM
  #134
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
how far of a reach do you need to get center? I have a friend that works at a tool and dye shop. you need it to cut a 5/8 hole correct? I just need to know how deep you need it to reach. No promises but I'll see what i can do.
Old Sep 29, 2005 | 10:54 AM
  #135
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
Can't wait, but another thing to think about doing is the HVAC controls along with the shifter plate (previously stated).
If both of those are done then it would all mesh together so to speak. Plus the shift plate would be the easiest on you. So when you get all of the kinks wrinkled out PM me and I will buy a set (gauges, HVAC, and shift plate) from you in a heart beat!
Keep up the great work, were counting on you.
Old Sep 29, 2005 | 12:39 PM
  #136
ColdSoda's Avatar
Car: 1989 IROC Camaro
Engine: 5.0TPI
I drive an 89 IROC as well. My gauge reads up to 115mph, but (as you may or may not know) the needle keeps going until it hits the trip reset. Would you be able to make a gauge that keeps the same number spacing (to avoid any speedometer changes) and keep the numbers going around until the trip reset? I think it’s about 130... But I am not positive. I would be very interested in purchasing this gauge set once you are done with the project. Also, just let me know if you would need any pictures for reference. Just let me know if I can do anything to help. Thank you for always keeping us updated on your progress!
Old Sep 29, 2005 | 10:04 PM
  #137
Abubaca's Avatar
Yes, I can make the spacing for whatever MPH you have. I don't have a template for it yet, but yeah, I'll be able to do it, no problem.
...and I'll figure out the template for the HVAC and shifter too. Anyone happen to have a set of overlays for those that I could use as a template?
.....but the good news is that I think I have a solution. I'm just gonna cut the punch into two halves!!!! It would make it tough to punch HUNDREDS of holes, but all I need is two per set. Speedo/tach. I'll see tomorrow at work if I have something to cut it with. Maybe a handheld hacksaw will work. OOH! I have a carbide cutting wheel for the dremel!!!
Old Sep 29, 2005 | 11:36 PM
  #138
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Damn Abubaca...your gonna be friggin rich!! That is awesome that you can do this...if you ever make any 91-92 overlays let me know...i want some!
Old Oct 4, 2005 | 09:30 PM
  #139
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
i have guage face envy
Old Oct 4, 2005 | 09:31 PM
  #140
montesa311's Avatar
d/p
Old Oct 5, 2005 | 12:03 AM
  #141
BlueZee28's Avatar
are you ready for mass production yet?! lol
Old Oct 5, 2005 | 01:17 AM
  #142
Abubaca's Avatar
Very close. Well, I dunno about "mass", but we'll get some sort of production rollin' soon.
I have to post up on the Mod board to see how i should handle it.
Old Oct 5, 2005 | 04:25 AM
  #143
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Very nice Abu. I'd buy em if i still had the iroc on the road.
Might be in the market in a few months!
Old Oct 5, 2005 | 04:22 PM
  #144
True_bird's Avatar
Car: 1985 Firebird
Engine: ***Bagged 2.8***
Transmission: 4 speed auto
count me in for a bird version when you get around to it these things look amazing good luck and keep up the good work!!
Old Oct 5, 2005 | 04:34 PM
  #145
Sinisterdrummer's Avatar
Car: 1991 Firebird Hatchback
Engine: v8 305
Transmission: Automatic
ditto.
Old Oct 5, 2005 | 06:32 PM
  #146
Car: 84Z & Porsche
Can you make the gauge face overlays in other colors? I saw a set of silver overlays, and thought they were just awsome. Keep up the good work, Ed.
Old Oct 5, 2005 | 06:59 PM
  #147
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
im intriqued in a set once the quirks are worked out
Old Oct 7, 2005 | 02:38 PM
  #148
roc city f body's Avatar
Car: 86 iroc z
Engine: 90 l98 vette
Transmission: 700r4w/all vette parts
those are the best looking gauges ive seen . want some bad, even your old ones.
Old Oct 7, 2005 | 03:08 PM
  #149
violentgod1's Avatar
Car: 1989 RS
Engine: 305 ci v8 LO3
Transmission: WC T5
I would be in for a set for my 89 rs. They look pretty cool.
Old Oct 7, 2005 | 06:14 PM
  #150
Abubaca's Avatar
OK, here's the latest update.
For those who've been following along, I've decided to see how well I can cut the center holes by hand. All attempts at some sort of punch have failed. I know I can do it, it's a matter of how much time it's gonna take to cut 'em. Obviously they can't be a hack job.
I'm hoping to have all the production issues wrapped up and have myself a "final draft" first set within two weeks.
Assuming I'm happy with 'em (and I'm feeling pretty confident ) I'll begin moving forward with putting them up for sale.
I've talked with some of the mods, and what we'll probably do is link and lock this thread, and start a new thread in the classifieds section with some more photos, prices, options, and all that good stuff.
The first few sets WILL BE 85-89 145mph faces!!! I want to be absolutely certain that I have no production issues with the existing layout/template. Once I feel confident that quality is up to par, and you guys have some feedback from a few other members, then I'll start moving forward with all the 82-89 Camaro faces. I won't lie to ya, I'm not really sure what I'm going to do about 90-92 Cammie faces or any Firebird faces. I'd really like to make 'em, but I don't have any templates as of now, and I'm sure there will be some more production issue just like with my current faces. The whole "backlit" thing is gonna be a challenge. No promises, but yes, I'm gonna see what happens, and hopefully I can make those too.
Stay Tuned.
If you are interested in 145mph/Iroc faces, shoot me a PM and lets talk.
