GTA door panel mod
Old Mar 22, 2005 | 01:17 AM
AlbertaFbody's Avatar
Car: 86 z28
Engine: 305 carbed with 3" Y pipe back
Transmission: 700r4 that is breaking down
GTA door panel mod
well i have searched and found out that with the gta molded door panels will fit into a 86 camaro z28 altho i have read many posts that you can put them onto the original arrow style arm rest mount or you can put the ones off a gta on there. now my first Q does my car have the arrow style arm rest mount ? also if it does can i just drill some new holes and get it to work with these?
thanks ahead of time
Old Mar 22, 2005 | 03:39 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
i believe you need the armrest mount specific to the gta doorpanels.. you could always try fabbing something up to make it work, tho..
Old Mar 22, 2005 | 05:29 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
if you have the donor car its best to get the metal bracket as well.
Old Mar 22, 2005 | 06:41 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You'll definately need those. otherwise the armrest won't mount up. I just did this. Drill a few holes and runs some bolts through and you're good.
Old Mar 22, 2005 | 09:19 PM
Diggler86's Avatar
Car: 86 TA
before & after
Attached Thumbnails GTA door panel mod-c-documents-settings-zach
Old Mar 22, 2005 | 09:29 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Did you have to change the actual handles as well as the arm rest brackets? I want to install the deluxe style handle trim on my 82, but there seems to be no place for the trim to mount to.
Old Mar 25, 2005 | 02:45 PM
LT1guy's Avatar
Car: 1987 Trans Am
If you need barackets check with Hawks; Bruce once told me he usually takes off the armrest brackets when he sells doors, so he may have some spares.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
Out-Cast
Aug 23, 2015 06:33 AM
