can u restore these things?
Old Mar 25, 2005 | 10:59 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
both of my door windows got scratched up bad because the felts on acouple of those brackets need to be replaced. i called around and everyone is telling me u cant get new ones anymore. u need to find used ones in good shape and hope u dont scratch up your new tint job again. is there a way u can restore the felts?or some way to fix them? theres got to be a better way... any info on this topic would be great! thanks alot
Old Mar 26, 2005 | 01:20 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
The felts that are attached to the upper door trim? You can still buy new door trim from Hawks and F-Body Motor Sports. I'm talking about the trim piece that covers the top of the door on the inside and is attached to the door panel. The outer window sweep also has felt I believe. You can still get new ones from GM as well as aftermarket ones. So far I have been able to buy everything that gos on or in the door either new from GM or aftermarket.
Old Mar 27, 2005 | 09:11 AM
shipfitter_sjd's Avatar
Car: 1992 Camaro RS Convertible & 1983 P
Engine: 305 TBI & 305 4 BBL & 4.7 liter
Transmission: Auto & Auto & 5 Speed Manual
Some People Call Them.......
Dew Wipers.
Ebay is one place to look, plus the other sites mentioned above. Year One Next gen also has them I believe.
Good Luck.
Old Mar 27, 2005 | 09:17 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
I think he's talking about the slotted metal brackets with the felt pads on them that bolt to the top of the inner door (under the door panel). They guide the window, unlike the weatherstrip that just seals the window.
Classic Industries sells them in their catalog (or check their website). They call them "Window Guide Stabilizers" PN# is G1201 and they're $9.49 each (2 per door). I was going to order them but they were out of stock and I found some nice used ones in the meantime.
Hawk312
Aug 22, 2017 08:55 PM
g.l.mos
Aug 22, 2015 12:02 AM
Bob88GTA
Aug 18, 2015 03:31 PM
gta power
Aug 13, 2015 06:15 AM
Street Lethal
Aug 12, 2015 11:33 AM
