clear coat over one stage enamel
Old Mar 29, 2005 | 04:00 PM
luvmy64's Avatar
I read in a magazine recently where they had a Nova painted at Maaco or something and put a coat of clear over the one stage enamel, instead of using a base/clear system. I thought you werent supposed to do that, due to the clear having a "magnifying glass" effect on the paint underneath or something. Can anyone tell me the pros/cons of this and has anyone had this done long term to see the effects? Also, would i wet sand before shooting the clear?
Old Mar 29, 2005 | 06:47 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Yes this was the way it was done before the true base clears were developed.
Actually most show jobs were single stage and wet-sanded between coats. (three on and one off) Then for a finishing touch, mostly with metallics, a couple coats of clear added for durability and gloss retention.
Depending on your color, you could still do this, yes you will have to wetsand the entire car, assuming the paint is more than a week old.
You may need a mist coat of the color over the old color. Metallics will require a couple coats of color to get the stripes out and the new metallic to lay down.
Depends on your time frame and budget, use a compatible clear.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
Stryker412
Sep 7, 2015 09:11 AM
