Fiberglass Repair Help
Old Mar 31, 2005 | 07:56 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Is it possible to repair a Whole in Fiberglass Hoods? I have a Harwood Cowl Hood I removed from my car years ago that was drilled for hood pins I would like to remove the wholes. Also can an armature do this? The wholes are about silver dollar sized and are now perfectly round. Can anyone list the items I need to do this repair cause I am going to go out tomorrow and by the supplies.
Old Mar 31, 2005 | 08:52 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
3M Automix Two-part rigid/SMC repair... Will require a special gun and mixer tips.
A small chunk of SMC will be helpful as well... but not necessary.
check my plastics primer
here, for details on how to repair
good luck, let us know.
Old Mar 31, 2005 | 09:03 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
So this 3M Automix Two-part rigid/SMC will work on larger things? Cause sounds like you are repairing small tears this is a whole maybe 3" at its widest spot. So no fiberglass and resin will be needed? I read your post the part where you wrote to make the tear shaped like a V what about if it’s a round whole?
Old Apr 1, 2005 | 07:44 AM
KEVIN G.'s Avatar
Engine: 305 CARBED
Yep, just tailor the repair method to your needs.
Use a small grinder to taper the edges of the holes, (do this on the inside and outside, without trying to make the hole larger.)drill all around all the holes with the pinning holes to add strength to the repair. For the first coat, you will need to loosely tape the back side of the hood to keep the material in place and just squirt it in the hole, spreading liberally with a spreader, remember to push it into the pinning holes. Let harden and pull the tape.
Grind both sides of your new repair to spread a new coat of material for a second coat. You will not need new pinning holes. Repeat until you get it to the level you need, (when you get close, start using a block and 80 grit to make sure it's straight.)
Finish the whole area with a final THIN coat and block with 120 finish with 240 and prime and block and prep for paint.
Old Apr 1, 2005 | 10:56 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
I wont be able to grind the back side the back side is inside the hood. I will take pictures.
Old Apr 1, 2005 | 12:34 PM
jay92,85,79's Avatar
Car: 85z28,
I would not use tape. Get some fiberglass backing. Y can't u use some fiberglass and resin? That 3m stuff works great but its not cheap. And if u don't have the gun that like 60 bucks.
Old Apr 1, 2005 | 03:41 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Well I have never done a repair like this before. So I didn’t think fiberglass and resin would be for armatures. But I have been reading all the fiberglass repair things I can online also talking to body shops for tips.
Old Apr 1, 2005 | 04:16 PM
Car: 85z28,
well if the hood is made out of fiberglass y would putting fiberglass back into be the way armatures do it. Thats how i would do it And I am a ASE bodyman. I'm not saying thats the only way it can be done U can to it KEVIN G's way or my way and I'm sure theres body guys out there that would do it another way. As long as it turns out. Strong and flat your good.
Old Apr 2, 2005 | 12:20 PM
KEVIN G.'s Avatar
Engine: 305 CARBED
Yes there are many ways to correctly repair a vehicle and it's parts. My way is what we do to repair SMC every day. (as well as bumper covers), It is not the only way...but more than likely the most recent/user friendly way.
This is kind of on the edge of what is being taught by ICAR,(which I am certified, as well as ASE, GM STG, PPG silver...) Their original plastics course teaches us to plastic weld using this technique.
Next week we will be attending a class for ICAR, sponsored by 3M, which will address these very issues.
The tape is just to keep the repair material in the hole until it sets up, by no means was it meant for strength. As hood pins are fairly small, the structure of the hood should be sound.
Fiberglass cloth works great to make and form patches and would also work very well here.
Yes this is key.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
