Car painting
Old Apr 5, 2005 | 11:54 AM
Kaas's Avatar
Car: 89 Iroc-Z
Car painting
Heya guys. Have decided to paint my car. in 89, chevy only had two different stock red colors...right? flame red and bright red i think....i can't read the paint code on my car, is to faded lol....but i am pretty sure it's flame red since it's a quite dark red. Where can i buy some of these paints. And what tips do you guys have for me and a buddy, as we are gonna paint it ourselves....and tips would be greatly appriciated....
Old Apr 5, 2005 | 03:58 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
here is a post titled painting steps maybe that is what you looking for or didn;t look for
https://www.thirdgen.org/techbb2/sho...hreadid=288583
Old Apr 5, 2005 | 05:03 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Look in your RPO codes you should see a Number then a U at like the very bottom.
That is your paint code.
Old Apr 5, 2005 | 05:05 PM
You should see a
74U for Flame Red Met.
Or 81U for Bright Red
Old Apr 7, 2005 | 02:43 PM
Kaas's Avatar
Car: 89 Iroc-Z
How important is it for me to use a "clean room"? i'm not meanin like not vacuming all the dust and such out of the garage, cause i will deep clean it before i decide to paint the car...but how important is it to have a room that has all the filters and such set up in it? and any opinions on what the best primer, then mix for paint and such..how many coats of each should go on (for a really good paint job that is) then clear coat etc....and anyone know where a good place to buy all the primers, base coats and clear coats at?
Old Apr 7, 2005 | 02:47 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Find a local paint supply store. Talk to them. Tell them what you want to do, and let them set you up. If they're open on a Saturday go then, cause they likely won't be as busy as they would be M-F.
Doing all the prep work, Sanding, removing dents, body filler, etc.. is the hard part. Actually spraying the car is easy.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
kyle5647
Aug 7, 2015 03:08 PM
