Pro 5.0 Hits Radio, help
Old Apr 5, 2005 | 07:44 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Well I installed a pro 5.0 along with a 4th gen center console and I ran into this problem. The Pro 5.0 is angled so far forward that its hitting my radio before it goes into gear. I thought maybe I put the base on wrong but I installed it with the writing right side up so I'm assuming that on correctly, it went in fine just it sits too far forward. Any ideas are welcome.
Old Apr 5, 2005 | 07:55 PM
Tonyrodz's Avatar
Transmission: auto
You can try swapping in a different mounting kit for the radio. I know they have flatter ones-instead of the one you have. That might give you that extra room you'll need.
Old Apr 5, 2005 | 07:57 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
ya could heat and bend the shifter. then send it out for chroming or powdercoating...Stupid option, but u'd need a second shifter for the time being. Or, pull ur radio until you can figure out a solution.
Old Apr 5, 2005 | 08:01 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I agree with bending it. Even if you moved the radio back a bit, well your fingers would probably hit it. Or be very close. And annoying. I say bend.
Old Apr 5, 2005 | 09:16 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
You must have the shifter reveresed or the stops are way off. I just took a pic of mine with the 4th gen console and a B&M shifter it shouldnt be that much of a difference. I have a mile of distance. In the picture mine is in first gear.
Old Apr 5, 2005 | 09:17 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Dont bend the shifter u have something out of wack and that will make it worse.
Old Apr 5, 2005 | 09:25 PM
Car: 1990 Formula
A guy in my local car club says he thinks when he installed his the writing was upside down, I put the writing in right side up as I figured that was the logical way to put it in. If anyone can verify the writing was up top (near the radio) and reads upside down that would be a huge help.
Old Apr 6, 2005 | 05:38 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
your shifter is on backwards....
Old Apr 6, 2005 | 06:58 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Yes, it is on backwards.
The allen bolts for the shifter handle, should have the heads facing the passanger side of the car.
Old Apr 6, 2005 | 08:06 AM
Car: 1990 Formula
Well you can bolt the handle onto either side so I can't go by that, but I have twice confirmed the writing should be upside down, it faces right side up on mustangs but not f-bodies. So if anyone else is buying one keep that in mind and save yourself a headache.
Old Apr 6, 2005 | 09:46 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got the Pro 5.0 and a 4th gen console and I have a lot of space between the shifter and the radio. I think I have the same radio mounting kit as you too.
I just went outside to take some pics,
1st gear,
neutral,
2nd gear
Old Apr 6, 2005 | 09:08 PM
Car: 1990 Formula
Okay I switched it around and it fits fine, although it doesn't go as far into 5th as it does any of the other gears. Its not touching the adjustable stops so I'm not sure whats up there, since the engine isn't together its something I'll deal with another day.
julian260
Car Audio
Sep 20, 2015 09:04 AM
Mr. Chevy
Sep 11, 2015 06:06 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
87camaro87
Sep 9, 2015 10:29 PM
