Out of ideas for door
Old Apr 7, 2005 | 08:09 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
Ok , i just got the new hinge bolts in from TDS and yes it did stop the door from going up and down, though it did not get my door back to its original position. I half way unbolted the bolts that attach to the hinge and the door and i jacked the door up to get it aligned right , then i screwed the bolts back in and when i let go of the jack, the door slumped back down into its old position... HELP! what the heck am i suppose to do now!?!?
Old Apr 7, 2005 | 09:25 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Use this tool.
Lon
Old Apr 7, 2005 | 10:14 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
tell me what this tool is gona do exactly. will it bend the hinge or something?
Old Apr 8, 2005 | 12:13 AM
lonsal's Avatar
Yes, exactly. The door hinges bend with time due to the very heavy weight of such a long door. This tool attatches to the door latch pin and latches to the door latch. Then you use a 1/2" drive socket and breaker bar to bend the hinge back to its correct position. I paid a lot more for a MAC tools door alignment tool before I found out about this version. By comparison, the MAC tool is very long and heavy and a hassle to store. But both tools do the job they are designed for.
Lon
Old Apr 8, 2005 | 11:14 AM
Faded's Avatar
Car: '91 Firebird
My doors seem to be sagging, but when I try to move them up and down they still seem very tight. Would this thing solve my problem, lonsal?
Old Apr 8, 2005 | 07:41 PM
lonsal's Avatar
Yes. I recommend to everyone to test your doors first (which you've indicated you have done) by opening the door and having someone raise and release the door as you inspect the hinges with a flashlight. If the hinges show signs of slop repair them first. If you still have an alignment problem, then use the EZ-Store door alignment tool to fix it.
Lon Salgren
Top-Down Solutions
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
aaron7
Aug 26, 2015 09:45 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
