what u all think
Old Apr 17, 2005 | 10:51 PM
jay92,85,79's Avatar
Car: 85z28,
what u all think
Yeah or no. I got this at the junk jard the other day. for 20 bucks the door was all messed up and there was a crack in the front that i fixed. So back to the door making one out of wood(yeah yeah i know) But it going to be a flat black like the rest of the counsel. Was thinking about putting 2 holes for cup holders. But I don't think its going to look right.So I could just cut that over hang off. What u all think
Old Apr 17, 2005 | 10:58 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
so what is it that your trying to say?
Old Apr 17, 2005 | 11:05 PM
Car: 85z28,
forgot the pic
Old Apr 17, 2005 | 11:51 PM
johnyIROC's Avatar
Wood + Cars = no.... except *Maybe* in a bently.
Old Apr 18, 2005 | 09:48 AM
burn rubba 83's Avatar
Car: 83 camaro z-28
Engine: 355
Transmission: 4 speed auto 700 r4
I like the idea i thind if you wrap it in vinal it will look pretty good.
Old Apr 18, 2005 | 01:01 PM
Car: 85z28,
i would like to do the vinal. But i know that i would mess it up. So going to primmer and block prim block. till u don't see any of the wood grain and than paint it flat black
Old Apr 18, 2005 | 01:03 PM
jojo22's Avatar
Car: 91 firebird
Engine: undecided thinking 383 stroker
Transmission: ??????????
i'd at least paint them satin black i've heard flat is a pita to clean
Old Apr 18, 2005 | 01:20 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
THat might be a bit too hard for your elbow after a while. I say pad it with foam and cover it in vinyl.
Old Apr 18, 2005 | 01:28 PM
jojo22's Avatar
Car: 91 firebird
is a good idea
Old Apr 18, 2005 | 03:57 PM
Car: 85z28,
I was thinking like a semi gloss. I might try to pad it. not sure yet
Old Apr 18, 2005 | 06:50 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
jay i like the idea except i dont think its practical cause my arm is always on the armrest where the cup holders would be. and you would want to at least pad it like the others are saying. some one did a tech article on here about installing cup holders in the ash tray aera. yoou might want to check it out if you didnt already
Old Apr 18, 2005 | 08:45 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
U painted some plastic in my truck on the armrests. Welp after 2 yars now it loks like *** b/c of my arm rubbing on it. Much like how parts of your steering wheel gets slick after quite a few years. I would wrap it if i were you.
Old Apr 18, 2005 | 09:31 PM
Car: 85z28,
Yeah I was that tec article. Was just thing of something diff. I thought the same thing about my arm being there. I don't think it will be a prob. I'm going to try it. If it don't work i can always cut that little bit off. lol. Not really worried about rubbing the paint off. Going to use dupon single stage with flater. So i think it should hold up.
Old Apr 18, 2005 | 09:43 PM
86project's Avatar
Make another pad....
Cut a peice of thin wood and place on top. Put it behind the cup holders, but flush with the rest of the edges of the wood. Go to Wal-Mart and buy padding and black vinyl. Cut a piece of padding to fit the top of the wood. Wrap the pad and wood in vinyl, glue/ staple, and place the unfinished edge down. From the bottom of your original wood piece, insert screws to bind your new cushion. Since the unfinished side will rest face down and be sandwiched, it'll look professional.
Pad and Cup Holder.
Since you wont have much wood showing, give the wood that shows a nice finish with stain and poly. The poly will help protect against big gulps.
Old Apr 18, 2005 | 09:45 PM
Car: 85z28,
Thats a pretty good ideal thanks
Old Apr 20, 2005 | 01:19 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Just get some 91-92 style factory firebird cupholders that mount on the doors.I got a set and there killer
Old Apr 20, 2005 | 01:31 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Round off those square edged first, then pad it and wrap it in vinyl. Then it would look good.
