LED's!
Old Apr 21, 2005 | 09:54 PM
FerrMaro's Avatar
LED's!
ok...I did a search on this like a good boy, but everything was about the dash lights or was way outdated.....when is someone going to offer LED tailights for our car? I loved the idea of being able to buy a kit for my car but then i read the post about the guy ripping everybody off with his kit. But it seems like everybody kinda lost interest...so i decided to resurrect the idea!haha.I'd do them myself if someone professional posted like a tutorial with a sticky or whatever that is..but yah..so ideas as so to how to do them properly? I'm not much of an electrician, so if its really hard then i'll just give up, but im milking this topic for all its worth cuz i really enjoy LED tailights.ok. im done. bye
Old Apr 21, 2005 | 10:10 PM
onebinky's Avatar
http://www.superbrightleds.com/led_prods.htm
Old Apr 21, 2005 | 11:46 PM
FerrMaro's Avatar
cool...thanks. which ones work for our cars and you just plug this into your car and go or is there some modifying and fabrication involved? sorry if this is a dumb question.
Old Apr 21, 2005 | 11:58 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
They plug right in. I forget the stock bulbs, maybe they were 1157s?
Old Apr 22, 2005 | 12:42 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
there was a guy on ebay that had a set of tail lights that he made with led's there had to be hundrends of them. came out really nice.
Old Apr 22, 2005 | 03:05 AM
FerrMaro's Avatar
o....cool. well if theyre so easy to access and to install, how come you dont see more people on this website with them??? Im getting them, ive decided..gotta go! bye.
Old Apr 22, 2005 | 11:37 AM
85_ZED28's Avatar
Car: '85 Z28
I think the problem people had with the 1157 leds in the tailight was that the light was to focused. The light doesnt disperse and just looks like a " hot spot". Also there can be issues with turn signals.
Old Apr 22, 2005 | 02:45 PM
onebinky's Avatar
There likely will be unless you add a resistor circuit, or design a time delay circuit. The factory flasher unit on these cars works off of amperage draw, and LED's draw almost none.
Old Apr 22, 2005 | 03:36 PM
Car: 86 T/A
Engine: HSR 355
Because they are more expensive and not really that cool.
Old Apr 22, 2005 | 04:23 PM
FerrMaro's Avatar
o
Old Apr 22, 2005 | 10:33 PM
FerrMaro's Avatar
well, ive decided to just get them...50 bucks wont kill me and if I dont like them then I just wont use them...i'll ebay 'em or something. The question I do have is about what size I should get. Should I get the 30 led bulbs, the wide angle 19 led bulbs, or the 24 led bulbs with 6 radially mounted led's. sorry for dragging on about this but I want to persue this and your guys' input is very helpful.Thanks..
Old Apr 22, 2005 | 11:38 PM
cdoyle's Avatar
The plug and play ones, don't work very good for tail lights. They don't light up the whole housing, and like someone else said, just create a hotspot.
What alot of people are doing (haven't seen any for camaros yet) but are making their own PCB's and retro fitting it into the tail light housings.
Take a look HERE, and see what some of these guys have done.
I've thought about it, but it would be expensive to do.
Old Apr 22, 2005 | 11:50 PM
FerrMaro's Avatar
geez...that looks hard.i wouldnt even know where to start. but i'd be willing to learn.maybe ill join over there and start something for us. o well...so much for the easy route.
Old Apr 23, 2005 | 02:22 AM
Abubaca's Avatar
LEDs have a lot of advantages, but most people in this hobby use them for color flexibility, and for added brightness. Neither of which is needed for tailights. You don't need to change the color of course, and I tested some hyperwhite bulbs in my tails and they were SO bright that I took 'em out. LEDs can be even brighter.
That's not to say they're bad. What the heck, give 'em a shot and like you said, if ya don't like 'em, take'em out.
Old Apr 24, 2005 | 02:55 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I think this is TheGreatJ 's car
Old Apr 24, 2005 | 03:04 PM
smokefan's Avatar
thoes look like the ones that i seen on ebay for sale. gotta like them
Old Apr 24, 2005 | 04:07 PM
FerrMaro's Avatar
wow...i want some.
Old Apr 24, 2005 | 06:29 PM
Stevo's Avatar
Car: Pair of 92 Z28s
i got led license plate bulbs there 194s they look really sweet at night.
i get people asking me about them all the time.
Old Apr 24, 2005 | 07:08 PM
cdoyle's Avatar
wow those look great, did he make those?
Old Apr 24, 2005 | 08:03 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
They are in this post...
https://www.thirdgen.org/techbb2/sho...light=led+tail
and his cardomain page...
http://www.cardomain.com/memberpage/332015/3
Old May 4, 2005 | 06:41 PM
flyingputz's Avatar
The turn signal snafu can be overcome with a Grote LED turn signal flasher #44891. It's not a "plug & play" though. The terminals have to be jumpered to the correct terminals in the flasher receptacle. Very simple. It also has an external ground wire that you must either put in the receptacle ground (easiest)or ground it to the chassis nearby. I've tried the "resistor" route, spent a lot of money on resistors that were supposed to correct turn signal problems. They DO NOT work properly, plus they build up EXTREME heat.
Old May 5, 2005 | 03:34 AM
FerrMaro's Avatar
interesting...
Old May 7, 2005 | 01:17 PM
Fast-Tony's Avatar
Car: 85' IROC & 87' IROC conv
Engine: Both have Vortec TPI 350
Transmission: T-50
Axle/Gears: 3:42 & 3:73
Steve
Where did you buy and what brand are the plate bulbs P/N?
Old May 7, 2005 | 06:55 PM
onebinky's Avatar
Originally posted by Fast-Tony
Steve
That link I posted above has them.
Old May 7, 2005 | 09:00 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
autozone sells a plug and play flasher that will solve the problem with the blink rate, it is for "trailer use" and is solid-state insted of working off a bi-metalic strip, also dose anyone make somthing similar to TheGreatJ's taillights, I really want a set.
Old May 9, 2005 | 01:03 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
hehe...I was just on Digikey looking for LEDs to pimp out the dash & taillights. I should soon be trying this out as well...
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
