Side Window tilt
Car: 82 Firebird
Engine: 5.0
Transmission: 3 speed auto
Side Window tilt
So I finally fired up my car yesterday and all was well. Then I tested out my window switch and my pass window wouldn't go back up. So I cracked open the door and stuck my charger to the motor to get it up again. While I have the door panel off I would like to know if there is an adjustment to the window tilt, as it hits the t-roof before the door closes, so the door doesnt close without a slam. I just need a diagram if anyone has it. I looked on my fbody cd and manuels and can't find jack.
Car: 1989 GTA
Engine: 350 TPI L98
I believe on interior side if you pull the doorpanel away you can see two metal brackets with felt pads on them that guide the window. The mounting holes on them are elongated for adjustment, just loosen the bolts and adjust.
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
