Removing Factory Decals to Prep For Paint
Old Apr 30, 2005 | 07:48 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
What is the best method to remove the factory decals from the nose of our Z-28.
We're a little afraid of sanding too much and screwing up the nose. Also the paper gets clogged with goo in a matter of seconds.
Is there a preferred chemical that will remove the decal (and the goooo) without damaging the nose under them?
Respectfully,
Kurt & Derek
Attached Thumbnails Removing Factory Decals to Prep For Paint-z28_dereknose1.jpg
Old Apr 30, 2005 | 11:24 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
if all thats left is the goo, try goo gone or acetate. both will cut the acetate would be quickest.
if the plastic part is still there use a hair dryer and a razor and carefullly raise the end of the decal and heat and pull slowly you may get most off in one shot.
jeff
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
3rdgenparts
Aug 8, 2015 07:09 PM
