recoloring seats?
Old May 3, 2005 | 12:40 PM
mustbeatmopar's Avatar
Car: 1991 pontiac GTA, and a1992 pontiac firebird
Engine: 5.7 l98, and a 3.1 for now
Transmission: 700-r4s
recoloring seats?
i have heard that you can use special fabric dye to color seats, is this a good option? i am in the process of eliminating the ugly tan interior of my bird in favor of black, installed a new headliner, carpet and painted the plastic molding(came out pretty good) now i need to do the seats and door panals. what should i do?
Old May 3, 2005 | 02:20 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I've used the Duplicolor stuff on the door panels and center console and would never use it on seats. I've had to reapply it twice to the center console lid...
Old May 5, 2005 | 11:36 AM
but do they make dye that i can apply to the seats? by the way, i used krylon fusion on my plastic trim and panels, turned out great. the key is to clean off the plastc with a solvent, otherwise the paint just runs off due to wax build up. got that info from my uncle, he works at a body shop, and paints cars on the side.
Old May 5, 2005 | 05:06 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Tried some Plasticote stuff on mine that were faded. Very little pigment, no color to it. To get the fabric even close I had to soak it and the fabric was really stiff afterwards. This stuff is not the trick anyway.
Old May 6, 2005 | 10:17 AM
bnoon's Avatar
Cloth or vinyl seats?
Old May 6, 2005 | 11:31 AM
86iroclamarque's Avatar
Car: 1986 IROC
Engine: 305ci DEAD FINALLY! 350 almost ready to go in!
Transmission: 700R4/Coming out TH-350 going in!
I did it to the cloth seats on my 71 Monte years ago. I took the seats out and used Rit fabric dye. It took a lot of soaking with dye and drying time but it came out ok. It did dry out the seat fabric though. If you have something to test it on I would try that first.
Old May 6, 2005 | 09:48 PM
Rebelhick's Avatar
Car: 86 TA w/ Recaro; 88 Formula 350
Engine: 305 & 355
Transmission: Autos
For cloth the trick is to gently clean them with a slight almount of a good cleaner. Something to get the grease off. Get a quart of dye from Year One or Classic and spray it with an el cheapo air brush that lets you put a lot on but is still finer than a regular spray gun. Don't use cans of air - you'll need a compressor. Forget the spray cans and guns - too much paint. Put on a coat, let it dry (it will dry fast because you're putting it on very thin), brush the cloth around with a hair brush or something equivalent (that will keep the cloth from laying down and becoming really hard and will help the next coat soak in and cover spots you miss). It's time consuming but if you have the patience it will work and will look much better than from a spray can. The color will come through again but just air brush it again as needed depending on how much wear the seats suffer. Vinyl is the same way just without the "brushing technique". FYI - Tan will come through on black paint over tan vinyl pretty fast, mostly around the edges of the seat where your legs rub against them when you're getting in and out and in the creases of the vinyl caused from weight.
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
