Best paint stripper?
Old May 5, 2005 | 11:20 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I got a good deal on some 5 spoke camaro rims but they were spray painted silver. I'm trying to remove the paint, I've tried some spray on stuff and brush on stuff from Autozone and both aren't doing too good. Is there anything better?
Old May 5, 2005 | 11:29 AM
foney_email's Avatar
Car: 97 200sx se-r, 82 Trans/Am
Engine: 350 bored to 355
Axle/Gears: 9 bolt 3.45
when I coated my wheels, I tried many strippers, but I learned sandpaper is the best method to use.
You can either sand down the machine marks or not. For keeping the machine marks, just get 0000 finishing steel wool, and use a circular motion. The steel wool gets you a good finish anyway, and you should use it as a finishing sand. Makes the wheel surface nice and smooth, and the paint sticks well.
Old May 5, 2005 | 12:27 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
I've heard airplane stripper works really well. I'm pretty sure Home Depot sells it.
Old May 5, 2005 | 12:30 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
I went to Lowes and got Klean strip semi paste, I also am Trying a brand Called Jasco, it seems a bit better,
You gotta get the paste so it will stick on there.
I'm doing rims now and I'm on my 7th application and its gonna be all gone after one more app.
The Key is to just glop it on thick and dont try to brush it all around...brushing it back and forth screws up the oxidation paint eating thing thats going on there. Try not to breathe the fumes.
Old May 5, 2005 | 05:03 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Just redid the wheels on my old Camaro. Real tough job. Best I found was some stripper at Walmart that had a little sprayer on the side of the can. Spray on a good thick coat, let it sit for 20 min. or so, then I used a pressure washer to blast off the paint. Cover up good and wear a face mask, that stripper burns. Then use some coarse steel wool and some of the stripper to really clean to bare metal. Final wipe with laquer thinner. Beautiful job when done - finally.
Old May 5, 2005 | 05:29 PM
Red|ine's Avatar
Car: '83 Z28
Axle/Gears: 3:73
You're going to ruin your nice pool table putting weights on it
nice rims though!!!
Old May 5, 2005 | 10:00 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Originally posted by little P
I went to Lowes and got Klean strip semi paste, I also am Trying a brand Called Jasco, it seems a bit better...
Yeah, I went to Lowes looking for Aircraft stripper & they didn't have it, so I bought the Jasco stuff. It works great. I brushed it on one of my GTA wheels and the clearcoat started bubbling up in about 3 seconds.
Old May 5, 2005 | 10:07 PM
jay92,85,79's Avatar
Car: 85z28,
I think u can only get Aircraft stripper for auto body store. But i might be wrong i kinda think i remmber seeing it at autozone. But that stuff works get.. Just make sure u were gloves and cover your arms.. Cuz that stuff burns like a B*%&$.
Old May 5, 2005 | 10:09 PM
GarageToys's Avatar
Yeah, they have it at Vato Zone- I saw it yesterday after I already bought the other stuff.
It definitely burns so pick up some good gloves- I got the green rubber ones that are solvent-resistant.
Old May 6, 2005 | 11:45 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
WalMart carries it too
Old May 6, 2005 | 09:25 PM
white91bird's Avatar
Car: 91 firebird
Engine: 305 TBI
Transmission: 700 r4
is it safe to use chemicals to strip paint off with the tires still on?
Old May 6, 2005 | 10:35 PM
GarageToys's Avatar
It's safe if you don't get it on the tires.
Just keep a bucket of water and a rag handy and if you get a little on the tire, wipe it off immediately with a wet rag.
Hotrodboba400
Dec 10, 2019 07:07 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
