What should be the final grit sandpaper on primer before spraying the color coat?
Old May 7, 2005 | 11:23 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I am finishing up the body work on my car and am getting ready to spray the color coat on it. The base in a PPG Epoxy Primer / sealer. How sine of a sand papar should I use when block / wet sanding the primer before I spray on the color. The Color coat is an Acrylic paint.
Old May 7, 2005 | 12:05 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i used 400 grit with sem guide coat to show the way.
jeff
Old May 8, 2005 | 02:45 PM
Loco Kano's Avatar
Car: 88 Firebird
Engine: 5.7 TPI
hmm
I used 400grit on my fenders and used 400 then 600 on my body to try a "smoother" look....it made no difference, dont waste your time with the extra step
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
