91 hood inserts removal
Old May 23, 2005 | 11:52 PM
cuda69's Avatar
Car: 91z28vert,3:42posi-rear,gu6
Engine: 305TPI
Transmission: T-5,pro5.0 shifter
need info on how to remove the plastic fake cowl ducts in my stock hood,i thought i could remove the two fasteners and on they would be loosened but that didnt work,something else is holding them on still,were they glued at factory?i guess i need to take off my insulation and really look at what is under there,but i was hoping to avoid that removal,any one ever had there inserts out? 1991 z28 vert 305 tpi,5spd
Old May 24, 2005 | 12:27 AM
stiers's Avatar
I am pretty sure there are around 6 to 8 bolts on the underside of the hood for each blister. You will probably need to take off the cover to get em out.
Chris
Old May 24, 2005 | 01:13 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
There are 8 nuts holding each blister on. You will have to remove your hood insulation to remove them. Same goes for factory hood louvers....
Old May 24, 2005 | 01:34 PM
cuda69's Avatar
Engine: 305TPI
Chris
Old May 24, 2005 | 01:37 PM
cuda69's Avatar
Engine: 305TPI
hood info
Old May 25, 2005 | 02:41 AM
911rsq's Avatar
Transmission: yes
Um......okay...????
You went from him saying "pretty sure" to getting a firm answer, but whatever?
Old May 25, 2005 | 02:31 PM
cuda69's Avatar
Engine: 305TPI
WHY DONT YOU WORRY ABOUT YOUR OWN AFFAIRS,AND NOT MINE
Old May 25, 2005 | 03:04 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
You, sir, are CRAZY!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Wife'sCar
Aug 22, 2015 01:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
