door panel plastic removal
Old May 24, 2005 | 01:56 PM
duz's Avatar
duz
Car: 82 Firebird
Engine: 5.0
Transmission: 3 speed auto
has anyone else here had troubles takeing the plastic rail off the top of their door panel? do i have to make a custom tool, becuse those fasteners are unnessicary don't make a lot of sense. its like a recessed bolt head (5/16) and then threads going up in a column through the center of it. retarded.
Old May 25, 2005 | 10:27 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What?
are you talking about removing the door panel from the door or the door panel from...?
you mean the "push outwards, then up" part?
Old May 25, 2005 | 10:35 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Use a pair of pliers to grip the outer ring of these little nuts. Becareful or the plastic will break before your very eyes.
Old May 25, 2005 | 07:25 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
Engine: V8 305 LB9 5.0 T.P.I
Transmission: THM 700 R4 Auto
is there a place to buy just tat black plastic strip at the top? mine got a crack in it, prolly due to winter or what not. My Door panels are mint except for this one lil crack which can only be seen with the door open but it bothers me.Can i buy just that piece anywhere or should i hit up a junk yard??
-Adam
Old May 25, 2005 | 11:39 PM
Charlie's87's Avatar
Car: '87 t-top, '88 'vert
They actually make a special tool to remove those speed nuts, here's a link to a good thread on it:
https://www.thirdgen.org/techbb2/sho...90#post1872590
Old May 25, 2005 | 11:44 PM
Kandied91z's Avatar
-Adam
gm still caries them. very, very expensive. chances of finding a nice set at a yard are extremely limited. as far as taking them off they make a tool yes, it doesn't really work although if you have never taken one off it helps a little.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
