4 point roll cage for third gen
Old May 25, 2005 | 09:31 AM
98_LS1's Avatar
Car: 87 camaro, 98 Z-28
Where can I get one? I've been looking around and all I see are 6 to 8 point cages. I don't want bars running down next to my dash, all I need is a two post roll bar running across the back seat with two support bars running back into the hatch area, I know somone makes them because I've seen several around but I can't find any on the internet. It will be used for road racing, thanks
Old May 25, 2005 | 11:38 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
http://www.livermoreperformance.com/...html#roll_bars
Old May 25, 2005 | 12:53 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I noticed that they had a bolt in setup instead of weld in. How is that compared to most sanctioning bodies when it comes to passing tech?
Old May 25, 2005 | 03:43 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Not sure about that one actually. Someone recently posted about the Autopower rollbar on the chassis/suspension forum. It can't be further back than the third page. I would suspect the weld in would pass tech but the bolt in would not, but that is just a guess.
Old May 29, 2005 | 12:50 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
Last time I checked they may have verry well changed it since then But In a unibodied car a cage can be bolted in with the use of two 6"x6" steel plates one on the top and one on the underside of the floor. They have to bolted together with the use of 9/16" grade 8 bolts or bigger. But once again not sure any more I welded my cage in.
Old May 29, 2005 | 04:47 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
not just the floor pan mounts but at every joint it looks like there are bolts and zero welds.
Old May 29, 2005 | 09:31 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
no that wont pass tech the joints have to welded with a mig or a tig
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
LittleFranks
Aug 20, 2015 03:55 PM
z28addict8490
Aug 7, 2015 08:48 PM
