Rust/Rot around license plate
Old May 25, 2005 | 10:35 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
Hey guys this IROC I have is a little tender behind the license plate. It's that piece of sheet metal that runs between the rear 1/4's and the tail lights mount to them.
Any idea where I can locate patch panels or a replacement panel? I looked at Classic Industries and the didnt have anything.
If not I will be doing some custom work!!!
Old May 25, 2005 | 10:53 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
you could always go hunt in the local junk yard
Old May 25, 2005 | 11:23 PM
jay92,85,79's Avatar
Car: 85z28,
Its called the rear body panel.. I don't think they make patch panels. Like Pew said hit the yards.. Or maybe do a search on camaro rear body panel
Old May 26, 2005 | 03:57 AM
RestoRoc89's Avatar
Car: 1987 Iroc-Z/1993 Z28/2011 Corvette
Engine: 350 CI TPI/355 CI LT1
Transmission: 700R4/D&D Performance T56
Axle/Gears: 3.27 9-bolt/3.73 10-Bolt
You definitely won't find a replacement rear panel. However, I suggest posting an add in the 'parts wanted' section. I did and found a member quickly who was willing to cut out the section I needed from a wrecked car.
Fronzizzle
Feb 9, 2017 09:31 AM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
