Aero Wing Help
Old Jun 4, 2005 | 02:00 AM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Aero Wing Help
Just picked up a fiberglass aero wing for my car from a private party. From some of the searches I've done, the wing came with some mounting hardware that I didn't get.
? is can I use the original mounting hardware from the ****ty
rubber aero wing or is there special hardware needed to mount the fiberglass one.
Also, the wing doesn't sit flat. The driver side tip sits up around
1-1.5", prolly because it was never put on a car and how it was stored. I imagine once its mounted it will pull down without any issues. Was anyone elses this way ? TIA
Frank
Old Jun 4, 2005 | 04:29 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Its supposed to be a direct fit so all u need is the clips down the sides and the 2 bolts at the back. As for it sitting up once u slide it in the clips it shoud be fine.
Old Jun 4, 2005 | 07:37 AM
colonboy14's Avatar
Car: Trans Am
Mine came with two clips that went around the hatch metal frame that attached to the front of the arms, and then the bolts in back. And mine was a lttle distorted too, but it'll bend a little bit when you start tightening it down.
Old Jun 4, 2005 | 10:13 AM
LUVmy92's Avatar
Car: Camaro
Same problem with mine, sat real high in the center but when it was bolted down it was fine. However the cheap aftermarket spoiler is wavy as hell which kinda pissed me off but it still looks good.
Old Jun 4, 2005 | 02:53 PM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Are these the only clips that are used ?
Appears that the factory wing ( I haven't pulled it off yet ) clips to the metal strip on the rear glass in three locations on each side. The fiberglass wing has landings for the clips as well. So is it that only the front ones get used ?
Maybe what I should be asking is, does the fiberglass wing mount at the same places as the factory unit and if so is the hardware the same? Can the factory clips be used to mount the
fiberglass unit ?
Thanks again
Frank
Old Jun 4, 2005 | 07:56 PM
BirdofFireBOB's Avatar
Car: 88formulatp1
Engine: 5.0
Transmission: 5
I've got wing trouble too, are those factory clips still available somewhere?? The three up each side??
Old Jun 5, 2005 | 04:11 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
fiberglass unit ?
Thanks again
Frank
read my reply
okfoz
Sep 12, 2017 11:48 AM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
codeysabatini
Sep 24, 2015 05:40 PM
formula_novice
Sep 5, 2015 03:58 AM
