Door Skins
Old Jun 12, 2005 | 10:26 PM
Dk86Camaro's Avatar
Car: 86 Z28
Door Skins
Can anybody tell me what the difference is between a door skin for a camaro, and a firebird is... I did a search here and have been lead to the conclusion that the doors from a firebird and camaro or interchangeable. Looking at the information on http://autobodyspecialt.com/ they have separate listings for door skins for a firebird and a camaro, and the price is considerably more for a aftermarket skin for a camaro versus the firebird.. Any ideas on why this is?
Old Jun 13, 2005 | 08:30 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
probably popularity i guess, i assume the camaro's r more??? i could be wrong tho...
Old Jun 13, 2005 | 08:39 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
actually.. there is a difference between the dors from a camaro and a firebird. Learned from experience from an experiment.. the firebird door did not line up right the front was off.. So there is a slight difference.. Just like you can not put a firebird fender on a camaro or vise versa without changing the door..
Old Jun 13, 2005 | 07:56 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Sorry, but I'm about 99.9% sure that they're interchangeable.
(The doors, I mean.)
Old Jun 13, 2005 | 11:39 PM
Dk86Camaro's Avatar
Car: 86 Z28
Thanks you guys for writing… Just to add to my confusion I looked at my year one catalog, and listed in there under part number D45LH would be the door skin for a 1985-92 driver side GM for 199.00 each. Then under the block of text it says “NOTE: the aftermarket skins have been designed to work on all 1982-92 models”.
WILL85IROC: you are correct that the camaro is more on that website.
Angelis83LT: what exactly was not lining up for you?
KEVIN G.: based on this search I did..
https://www.thirdgen.org/techbb2/sho...hreadid=295458 I think that you are correct, but that is on a total door swap, what are the chances that the skins would be different? I would think that they couldn’t be much different.. Does anyone have some more sources for door skins other then Year One and that autobodyspecialt.com
Old Jun 14, 2005 | 12:30 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
So the doors are not interchangeable??? But I remember seeing somebody doing a early third gen camaro rebuild, and they took the doors off a red 1991/1992 Firebird and only removed the ground effects but got it to work just like it was a camaro door
Old Jun 14, 2005 | 07:22 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
friend has a 91 formula with a 86 camaro door on it, can't tell
Old Jun 14, 2005 | 07:59 AM
the door knockers on the post were not lineing up properly. could have just been a fluke in between doors though. I tend not to dwell to much on any one thing.. if it does not fit, i just go and get the correct model. But then it was on an 82 camaro, and the door was from a 90 firebird.
Old Jun 14, 2005 | 05:28 PM
KEVIN G.'s Avatar
Engine: 305 CARBED
Skins and doors are the same
Old Jun 14, 2005 | 09:20 PM
Technically doors and skins are not the same. the door skin is the outer most part of sheet metal seen on the outside of the door. it can be removed and replaced.
Old Jun 14, 2005 | 09:36 PM
KEVIN G.'s Avatar
Engine: 305 CARBED
I didn't mean they were the same part... I meant that they were the same for firebird and camaro
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
