Slow power windows
Old Jun 14, 2005 | 05:50 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
Slow power windows
I read an old thread that said that lubing them will help. Lithium grease?
Thanks Randy
Old Jun 17, 2005 | 03:45 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
Slow usually means they are the way out. I've replaced one, in the middle of summer no less, and now I need to replace the passanger side one. It is not fun work.
Old Jun 17, 2005 | 03:49 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Theres almost no slides to lube...
Most likely u need a new power window motor which stated above is NOT fun work...
what a pain in the ***.
Old Jun 17, 2005 | 06:16 PM
What about old batt cables? I know my motors probly need replaced, but the cables on the car are original, maybe they need replaced also?
Old Jun 17, 2005 | 07:18 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
I just did this today in fact. I pulled the driver's side door panel to clean/lube the window and dool lock parts and install new inside and outside handles. It is kinda hard to get to all of the three channels to lube them. Anyway, first I shot the snot out of them with WD40 and tried my best to get in there with a rag and pick up some of the old grease and dirt (helps to move the window to different positions so you can get to more of the channels). Once you get tired of that, then shot the snot out of it with lithium grease. Don't expect any miracles, but it is certainly worth you time. I recently had to replace my passenger window motor, and it wasn't cheap (after reading the how-to's on DYI I decided I'd rather pay someone else to fuss with it). Call around though and see if a body shop will be willing to do it if you bring your own motor. I only paid $20 in labor, but got shafted $180 for the part (it's like $70 at Checkers). That low labor price was in part because I pulled the door panel before I brought it in. Good luck with it! Thirdgens and their lovely 10 ton windows!
Old Jun 17, 2005 | 07:24 PM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
Now, for my curiosity, just how slow are we talking about here? I always thought mine were what we considered to be slow, but then I heard/read some people discussing greasing and whatnot, and getting times of almost 20 seconds to roll up! For me it's about 7 up, 5 down.. I thought this was real slow, but is it?
Old Jun 20, 2005 | 08:32 AM
Car: 1987 Trans Am
Engine: tree-fiddy
No joke about the windows weighing a lot. My ***, Doing this by yourself is not advised. especially now that it's hot outside and unless you have a nice air conditioned garage, you will be sweating your *** off, and the window will be that much harder to hold on to while you try to get it lined up and in the channels.
Oh and do this in the shade, glass gets real hot in the sun.
Old Jun 20, 2005 | 12:01 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
hahaha
I normally would never take my car in for ANY sort of mechanical work that I can do myself... But... After hearing the horror stories about this...
I'm thinking about pulling the panel, going and buying the motor, then taking it in.
Old Jun 20, 2005 | 05:10 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
First of all, slow power windows doesn't necessarily mean you need new motors. Really really really slow power windows does. But our windows are slow to begin with and there's not much of anything you can do about that. Grease helps a little.
Second, replacing the motors aren't as bad as everyone makes it seem. It's a pain in the ***, and you should count on scraping up your hands pretty good, but it's not that bad. Use a drill to drill out the rivets that hold the existing motors in, carefully pull them out, put new ones in and fasten them with bolts that are the same size as the hole that the rivets were in. It's about a two to three hour job per door, but you could be doing something harder.
Old Jun 20, 2005 | 05:21 PM
I havnt replaced mine, but when I do thats what I would expect it to be like. YES you could be doing something harder like replacing a flywheel!
Old Jun 20, 2005 | 06:42 PM
Car: 92 RS
Engine: a slow one
Replacing a flywheel isn't that bad to me.
Just don't try to take any shortcuts, it will make it easier on you in the long run to just rip the damn trans completely... It's only a U-Joint and a few more bolts anyways.
I took a look at the window motor a few minutes ago and it doesn't seem all THAT bad. Do I have to remove the entire window assembly?
Seems like I could just drill out the rivets and pull it out from underneath without messing with anything else. Looks like a fairly quick and straightforward job actually, but I couldn't see how it was mated to the gearing on the window...
How involved is that part?
Old Jun 21, 2005 | 02:23 PM
Car: 1987 Trans Am
Engine: tree-fiddy
The scissor assembly will invariably be in the wrong position when you lower the window, and it will take 3 tries to get all the rollers in the tracks. And at some point you will loose grip on the windown and it will make the scissor part pinch your hand in the door.
It really isn't that hard, but for people with big hands it is a pain moving it around in the door trying to get the right angle on everything.
Old Jun 21, 2005 | 04:39 PM
I took a shortcut in putting the flywheel in, put 4 longer bolts in slid the traine back, even left the drv shaft in, no problems.
Old Jun 21, 2005 | 06:10 PM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Just to ask again - how slow is slow? I'm getting similar times to Justin - less than 10 secs each way.
Mark.
Old Jul 14, 2005 | 04:16 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
this has been discussed over and over but here are my results.....
i thought my windows were slow (approx 6 seconds for both up and down; but the pass side would stop with about 2 cm left and need a rest). after some research i found you could run some relays to the window motors and speed up the windows. the window motors do go bad but in all honesty if you are around 10 seconds and the windows go all the way up and down dont mess with changing them, you dont need to.
if you want to speed up your windows you need to make sure you're electrical system is in proper order, which i will bet you it isnt. these cars are at minimum 13 years old and everything is starting to go out on them. run new power and ground wires from your battery (or distro blocks inside the car) to your window switches (if you dont tie into a switched power source you dont even need your key to operate the windows, which comes in handy). that was my main culprit. but remember its more than likely not only one problem with these old cars. next run new power and ground wires from the switches to the window motors themselves. you wouldnt believe what new wiring will do for your car. finally for good measure take apart the tracks inside the door and clean them very very well and lube them up again. if you would like you could install new motors and you would then have the best thirdgen windows possible.
but take that info elsewhere....run new wiring to your headlights, foglights, fuel pump, electric hatch release, door locks etc etc and your car would start to work like new again!
any questions just ask
Old Jul 14, 2005 | 09:26 PM
Faded's Avatar
Car: '91 Firebird
I didn't think it was half as bad as everyone here made it out to be. I didn't have any problems sliding the motor/scissors in and out of the door.... just mark and take out the bottom bolt out of the track that's in the way. It was rather simple. =P
I think the longest part for me was cleaning the inside of the door and laying down some soundproofing.
Old Jul 14, 2005 | 09:29 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
yea im sure it isnt that bad but i just didnt bother with removing the stuff. after i found out new wiring was needed i didnt hassle with it. i did lube up the three tracks inside the door tonight though and while i didnt notice much of a difference at all i feel much better that i at least slapped some white grease on them.
Old Jul 15, 2005 | 12:29 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
my driver window takes a good 15 seconds to roll up and the passenger takes about 8. i have new motors ready to go in but i heard that you should riviot the motors in instead of bolting them. is this true
Old Jul 15, 2005 | 06:36 AM
Difflock's Avatar
I suppose riveting is quicker and easier, probably cheaper too.
Driver's window on mine suffers from some kind of dodgy connection (if I power it all the way down then it won't come back up without plenty of fiddling with the connector etc. - work around is don't power it all the way). Speed-wise the windows are fine, thanks guys!
EDIT - took the opportunity to add grease to the tracks and gears when I fitted new weatherstrips on the door tops.
Mark.
Old Jul 15, 2005 | 06:43 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
i never heard dont rivet them...bolting them just makes it that much easier to remove in case they need to be taken out again
Old Jul 15, 2005 | 03:19 PM
smokefan's Avatar
i do beli=ve i heard it on this board or at a body shop. i cant remember where though but they said that because of the movement and torque of the motor it will loosen up the bolts
Old Jul 15, 2005 | 03:47 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
her power door locks and windows were slow or didn't engage all the way
pulled the panels off
hit it with white lithium greeze in the can
and they work nice now, almost as good as new
i personally hate GM power windows, they are always slow
Old Jul 15, 2005 | 05:49 PM
smokefan's Avatar
my friend has a 79 rs and his windows are way too fast. i would love to have a set of motors like that in my car.
Old Jul 16, 2005 | 03:52 AM
Friend comented on my power windows, he says we can have ah whole conversation while I put the windows up on my Camaro. he has a mid 90s eagle Talon, the power windows on it must have a turbo charger on them! Damn there fast
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
