GFX Rubbing
Old Jun 20, 2005 | 09:14 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
GFX Rubbing
As you guys know, im installin 91-92 GFX on my 88 iroc. I was suppose to have my doors fixed (they slumped some) but the damn body didnt do it right. Do anyway, im installing my new rocker panels, to find out the door slightly rubs up against the rocker panel. Anyone else had this problem?
Old Jun 21, 2005 | 04:22 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
bad door pins will cause that very common problem. get the rebuild kit from hawks it has nice bearings and is made specific for our cars.
jeff
Old Jun 21, 2005 | 10:28 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
If they are spaced apart when closed but rub opening and closing its the hinges.. If they look like they are touching closed it's probably the metal mounting strip. Take the GFx off and beat the strip down a bit, then reinstall.
Kevin D.
Old Jun 22, 2005 | 12:05 AM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Kevin D.
Can you provide a picture by chance?
MrPackstin
Oct 25, 2017 08:09 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Veaceonee
Sep 29, 2016 08:15 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
snakeshooter
Sep 7, 2015 11:15 AM
