what to get?
Old Jun 25, 2005 | 05:34 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
what to get?
i need some recommendations as to what compressor and spraygun to get. i dont want cheap crap but i would like to get out of it as cheap as possible. for a spray gun i was looking at devilbiss hvlp guns, but there were a bunch of different models, what does every1 recommend?
Old Jun 25, 2005 | 06:07 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i got two finishline III they work good for the price, the gta or gti is the top line of devilbiss.
Sata is a great gun if you want to spend for the best.
as for compressor stay away from sears there all to small. Get a 240 volt two stage from lowes or home depot bigger is better when spraying. i used two sear compressor when i sprayed and it worked fine one would not do that job. you need cool dry air to spray the best. you do not want water in your lines that is disaster when it hits the paint...ask me how i know.
jeff
Old Jun 25, 2005 | 06:48 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
so would this compressor suffice?
here im not sure if it is a dual stage or not but even if it wasnt would it be powerful enough?
