ouch....fender support rail help
Old Jun 28, 2005 | 01:00 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ok i had the body shop check and the frame is not bent,
this is a 92 rs 25th anniversy i bought off an insurance company
how do i bend/ pull this back into place? what tools do i need, and any tips fender on fender off?
how bad is this
Old Jun 28, 2005 | 06:56 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: ouch....fender support rail help
Yes, yes it is. see where you're holding the washer fluid bottle, the fender is bolted to the frame.The strut tower appears to be touching the master cyl as well... shouldn't be quite that close.
If they were talking about the overall car being tweaked, might not be but, the front is boned
You're going to need to find a good frame repair shop and some donor parts. Most of that can be pulled back into place and at least a section between the strut tower and rad supprt appears like it will need to be sectioned in.
I'm not a pro... just my opinion.
Old Jun 28, 2005 | 11:59 AM
sellmanb's Avatar
Car: '86 Berlinetta
get a new fender, inner fender, and core support, put them on, then send it back to that frame repair shop and since they lied to you, tell them that they get to fix it for you for free
edit: oh, and a new hood. The hood is salvageable, but you'll spend more money at a body shop to have it fixed than you could get one from a junkyard and have it repainted proper color.
Old Jun 28, 2005 | 05:25 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
No, no that hood is not "salvageable"
There are convoluted reinforcements on the back side of the hood that are most assuredly damaged. And as such, are not repairable.
And if someone tells you they are, they need to be flogged.
It IS a saftey issue, the hood will never react the same in another crash, if repaired.
Now, is your FRAME damaged??? The only way to tell is to measure it. If they didn't do this , you really don't know.
The part you are looking at is the upper rail and apron...While structural, not really a "FRAME" rail. But, by all means do not take this lightly, while it CAN be damaged, and no damages to the rail, the strut tower may be moved, as well as the apron.
Old Jun 29, 2005 | 08:53 AM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
yes, the "frame" is damaged, and by frame i refer to the unitised body that IS the car, the car IS the frame. it needs worked plain and simple.
Old Jun 29, 2005 | 11:55 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Get a new fender and hood, wheel well, from a junkyard off a decently straight car. bolt them up and see if the geometry of the strut tower is corrected.
it may just be all of the mounting points are screwed off, it looks like the hit was kind of high, so it most definitely could've just bent the sheet metal back while leaving the actual frame rail below alone.
if the strut tower is still all pushed in like that once the new stuff is bolted in, or if you have considerable problems bolting in the new stuff, your frame is probably bent.
if so, i'd just put it all together, find a replacement rim and such, spraybomb it real quick, and sell the car as a daily driver.
plenty of 16year old kids who want a cheap camaro to beat the crap out of anyways.
also... if the insurance totalled that car and then kept it, the frame is probably bent. because it wouldn't have cost them hardly **** to slap a new fender and hood on there.
Old Jun 29, 2005 | 08:12 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
id start checking out prices again we are talking about todays rate of 100 an hour, even if it was purely cosmetical an actual body shop doesnt like to bend into place they like to repair,
its 7K in dammage but speak to the right person and can get it done for 1K minus painting
gixxer92
May 18, 2017 11:20 AM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
Briandrex
Oct 5, 2015 06:20 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
Twinn Engines
Sep 25, 2015 06:27 AM
