seat mounting bolt/nut
Old Jun 28, 2005 | 07:50 PM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
I need to know the proper size...two of my old nuts (ones with the washer nut combo..) were really badly rusted and i rounded them off pretty bad preparing to put in my new interior and anyhow...
i went to ACE and got 5/16 nuts and nice thick washers and the nuts will only turn onto the studs about 2 turns and get stuck so i know they arent the right size
does anyone know the right size nut...metric i presume?? 8mm??? i tried course and fine threaded 5/16 and they dont work
please someone respond quickly to this someone surely has had to replace these nuts due to rust and crap
Old Jun 28, 2005 | 08:13 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Not sure on the correct size, but 4th gens use the same bolt sizes. Rip one outa a J/Y. BTW, i think they are fine threaded and not course... That could be why those specific 5/16's won't fit.
Old Jun 29, 2005 | 02:52 AM
Car: 1989 GTA
i tried both fine and course didnt make a diff both did the same thing
Old Jun 29, 2005 | 06:16 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The front seat mounting bolts are METRIC and take a 13 mm hex size. cant give you the metric threads size, but now you know what to look for.
Old Jun 29, 2005 | 07:53 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
FYI, GM started using mostly metric fasteners begining in the late 70's ...
The drivetrain is about the only thing that still used standard.
Old Jun 29, 2005 | 04:31 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
I think its 3/8 or 5/16
Old Jun 29, 2005 | 06:58 PM
Car: 1989 GTA
Problem solved fellas
13mm hex nut with 8mm thread hole goes on just right
thx for the help
Old Jun 29, 2005 | 08:34 PM
DJP87Z28's Avatar
You shouldn't think so much, and just read.
Old Jun 30, 2005 | 10:33 AM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
was I wrong?
Old Jun 30, 2005 | 12:08 PM
DJP87Z28's Avatar
was I wrong?
Only you know for sure or read Posts.
Old Jun 30, 2005 | 12:43 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
Oh ok
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
mrdevontay
Sep 2, 2015 08:04 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
