Headliner question
Old Jun 30, 2005 | 08:40 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Headliner question
I am gonna redo my headliner and teh tech article said in the damaged areas to use fiberglass cloth and spry the adhesive on it but mentioned nothing about using fiberglass resin. Will the adhesive harden the fiberglass? Has anyone coated the entire headliner in fiberglass? Thanks for the help in advance.
Old Jul 3, 2005 | 10:15 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I have done my entire headliner in fiberglass. I used the fiberglass resin and hardener. I didnt follow the instructions as closely as i should have. For one thing i didnt realize to MIX MIX MIX. I mixed for like 3 seconds and it didnt come out that good. I just did the top part of the headliner. The sanding on mine was a biatch. Since i didnt mix good, there were bubbles and sharp areas that needed the good ole dremel to get them to where they should be. That took by far the longest part. I went to the fabric store bought some felt like material and some 1/4 in. foam glued the foam to the fibergalss and then i stapled the fabric into the cardboard and fiberglass. That hurt, the first staple was in a thin spot with a staple that was too long and went right into my finger. After it was all said and done I love how mine looks and it is the first thing that people complemnet on my car, for now any quesiton I can try and help with, I am no fiberglass expert but I can lead you away from my mistakes.
Old Jul 5, 2005 | 07:35 PM
trueburton's Avatar
Ok so I've never done fiberglass before. I bought the fabric and the resin. What is this hardener? Do I need it? Probably a stupid question. Thanks for any help.
Old Jul 5, 2005 | 07:59 PM
Engine: 388 Carb
Axle/Gears: 4.10
check to see if the resin came with a small tube mine did that was the hardener. Yes you definatly need the hardener, Mix it good. Good Luck.
Old Jul 5, 2005 | 08:18 PM
trueburton's Avatar
no it didn't come with any thing else.
Old Jul 5, 2005 | 08:36 PM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
Without hardener, it's never going to dry, it'l just stay in it's current state.
What brand of resin do you have?
Old Jul 5, 2005 | 09:50 PM
trueburton's Avatar
bondo
Old Jul 5, 2005 | 09:52 PM
Car: 1982 Z28
Engine: 350 HO
The kind in the metal can with the white plastic top? Hmm, it should indeed have come with a tube of hardener, as I think I've bought that exact same stuff before for other purposes.
Old Jul 6, 2005 | 06:05 PM
trueburton's Avatar
yeah that's the kind but not extra tube with it. I'll run back to Autozone and pick some up I need more fiberglass cloth anyways.
Old Jul 6, 2005 | 06:17 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
im doing this right now, its coming out ok, just make sure to get rid of any sections of your headliner that the yellow stuff is like seperating into layers on yours first, it will save you alot of head aches and just take your time. the sanding is the hard part, but makes it worth it in the long run.
Old Jul 6, 2005 | 06:42 PM
trueburton's Avatar
thanks for the tip. I just sprayed the cloth on last night and i will start spreading the resin tonight?
Old Jul 6, 2005 | 06:52 PM
Car: 91 formula
Transmission: t5
sprayed the cloth on ?
what you do it, do a coat of resin, let it dry then put another layer on with the fiberglass cloth or mat and put resin over that, and let it dry, and you can then put one more layer of resin on, and then sand it smoth
Old Jul 6, 2005 | 07:11 PM
Engine: 388 Carb
Axle/Gears: 4.10
I only did one layer and it came out fine, its been almost 6 months ago and it has help up so far.
Old Jul 6, 2005 | 09:59 PM
trueburton's Avatar
I sprayed glue on the backer first to hold the cloth in place. That helped eliminate any wrinkles in the cloth when applying the resin.
Old Jul 7, 2005 | 08:23 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
On my 89, I went over the whole thing with resin, sanded it down, and painted it the same color as my car... It looked really good, everyone complimented me on it
Old Feb 8, 2006 | 06:29 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
i have no experience with fiberglass. and was wanting to do this to my headliner as well. but along the lines of having it painted rather than clothed. how big of a pain in the *** is it, minus the sanding. and does any one have any pictures of their finished product? i would like to see how it turned out. if any one has a step by step of what to do for a beginner, the glass part. not the removal of the headliner, would be great.
semper
Frozer!!!
Jan 19, 2024 04:55 PM
Victor6
Aug 30, 2015 02:09 AM
Golfvette
Aug 24, 2015 06:35 PM
redmaroz
Aug 16, 2015 11:40 PM
TheJoeY88
Aug 13, 2015 06:51 PM
