dash panel doesn't want to come out...
Old Jul 3, 2005 | 12:38 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
...and i can't see why. took out the center console and what i thought was all the screws holding the dash in, but still doesn't want to come out. seems to be caught on something in the middle and looks like all the duct work wants to come along with it, but no joy. any ideas? i was taking it out to get to a certain component, but figured out another way. in the meantime, i figured i might as well clean it all up and clean the ducts while i'm this far with it, but for now, i'm as far as i can go. i just want to get it done and put back together so i can go pay lots of money to have someone else fix my car... thanks.
KAM
Old Jul 3, 2005 | 08:00 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
There isn't much holding the dash board in. There are bolts at the top and bottom corners. There is a metal bracket sandwiched in between the steering column so those bolts need to be loosened, then the screws for the speaker brackets and the brace in the center. The dash should come right out. The air vents are attached to the dash board. The dashboard was assembled and installed into the car as one peice at the factory.
Old Jul 3, 2005 | 09:54 PM
Car: '91 Z28
Axle/Gears: 323's
that's what i thought, too, but i'll have to take another look at it tomorrow. the metal framework along the bottom stays in place, right? and that center brace just needs to be unscrewed from the top and bottom? it's all loose as heck but doesn't wanna pop out. it seems to be hung up on that ductwork, maybe i just need to tug a little harder. i'm just a little afraid of breaking something. i have all the wiring detached from it, so i know the harness isn't holding it in there.
KAM
Old Jul 14, 2005 | 03:30 PM
KissThis's Avatar
Car: 1984 Firebird V6
I don't know if you got this under conrol, but there are a set of screws in the openings for the dash pad, I just took mine out with no problems.
Old Jul 15, 2005 | 10:50 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
keep looking cause you must of forgot something there. once all the bolts are off it does come right out. first time was a pain but by the fifth time it gets much easier
Old Jul 16, 2005 | 11:10 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
just wondering if you removed the wiring from the dash? that holds it in also it has zip tie looking things holding the wiring to the dash i just took one out of my 84 2 days ago
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
IBrockZ
Aug 20, 2015 12:20 PM
Street Lethal
Aug 14, 2015 08:25 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
