dome light removal.
Car: 1986 Pontiac Trans Am
Engine: LG4 305
dome light removal.
how in the heck do you remove the dome light, there are no screws anywhere that i can see. can someone help me?
thanks
thanks
Axle/Gears: 9-bolt/3.45
There should be two tiny posts(behind the lense, one on each side of the light), and each post has a tiny, round, flat, push-on "nut" that looks like a washer.
Pry those tiny nuts off carefully with a small flathead screwdriver; or even easier, use needlenose pliars to grab the edges of the nut and, with a little twist, pull it downward and off.
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
