Hood time...
Old Jul 18, 2005 | 10:02 PM
Gr89RS's Avatar
Car: '02 Z06
Hood time...
Guys i am having trouble with my stock steel rs hood, the gap from the hood to the front bumper is big, and i know its not the front bumper sagging.I can look into the gap and see that the spring on the hood isnt resting in the little recessed circle its supposed to rest in, it is sitting on the upper "wall" of that little circle, causing the hood not to close all the way, what do i need to adjust to make the spring sit in the hole properly?Thanks a billion guys i just dont want to make it worse than it already is trying to mess with it.
Old Jul 18, 2005 | 10:08 PM
Gr89RS's Avatar
Car: '02 Z06
Forgot to add that most of the time it only opens if u have someone sits in the car and pulls on the latch while someone else opens it.
Old Jul 19, 2005 | 01:16 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
that is not good. I had my hood flyoff and almost hit my friends car he was following me in is gay focus. I had my t-tops off and watched it lift off and land in back of me. it was funny
Old Jul 19, 2005 | 02:23 AM
Gr89RS's Avatar
Car: '02 Z06
Well i toyed around with the latch mechanism and was fortunate enough for the hood to close and the spring to hit the right spot.I did have to bend the spring several times to remove it from its crooked state though. Its a temporary fix i will probably be needing a new spring because with my luck the next time i open the hood the spring wont hit right again.
Old Jul 22, 2005 | 05:42 PM
Adrenaline's Avatar
Car: 92 Camaro RS
Number 1 reason for hood pins in the front. nearly impossible to get the hood open by myself, such a PITA...
Old Aug 6, 2005 | 11:15 PM
Anvil's Avatar
Most of the time it is the hood cable stretching.;
I went to the fishing dept. in the hardware store and bought crimp-on fishing line weights. I used one about 3/8" ,crimped it on between the end and the loop it goes through on the underhood mechanism. You could also get the spring from the junkyard off a big car ie Cadillac.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
