HELP-Hood hinge question ASAP
Old Jul 22, 2005 | 06:11 PM
dcs13's Avatar
Putting this car I bought back together. Replacing most of clip.
I got a hood from what I think was an 85 model for my 86. I didn't get the hinges because I figured mine were ok...Well, I think mine are bent. They will not attach to the hood. There is too much of a "curve" to them. (although they look the same)
So are ALL the hinges the same????
Guess I will be heading to the junkyard to get the ones that were on the hood, but wanna be sure...Thanks
Old Jul 22, 2005 | 09:26 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
AFAIK all the hinges are the same.
Not sure if firebird and camaro hinges are interchangable, but that shouldn't be your problem anyway.
Do you know in which direction the hood was damaged? If it was bent upwards badly (folded) then prolly the hinges are bent.
edit: profile info, or a signature line with info about your car will help others help you in the future.
Old Jul 23, 2005 | 07:03 AM
dcs13's Avatar
Thanks. Thats what happened to this car. Someone ran it under the back of a truck and took out the hood and core support.
I appreciate the help
BlueIroc-Z
Jun 9, 2019 03:22 AM
86IROC112
Apr 9, 2016 10:20 PM
92GTA
Apr 9, 2016 07:39 AM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
