Window Crank Removal
Old Aug 10, 2005 | 06:01 PM
jerpoh's Avatar
I was about to remove my door panels when i realized...HOW THE HELL DO YOU REMOVE THE MANUAL WINDOW CRANKS WITHOUT BREAKING THEM???? Just one of those things i never really realized was there. haha Any suggestions?? thanks a lot
Old Aug 10, 2005 | 06:13 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
They make a special tool for removing them. There is a little c clip the holds them on.
Old Aug 10, 2005 | 11:34 PM
jack_sparrow's Avatar
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
if you use a spring hook and get it to latch onto the c clip. it'll work nicely then jsut slide it off.
Brett
Old Aug 11, 2005 | 05:28 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Axle/Gears: 3.42 / 3.42
yup....just get the tool and push up and it slides right off......I forget how much the tool costs, but it is definetley worth it....no problems or damage...just don't loose that little wire clamp!
Old Aug 13, 2005 | 01:36 PM
jerpoh's Avatar
Thanks a lot, ill look into finding that tool. Thanks again
Old Jan 24, 2006 | 03:53 PM
kingair130's Avatar
Car: 1989 IROC-Z/T-tops
Hi guys,
My car stock comes with power windows and locks. The passenger door was all banged up, and the replacement door I have is crank windows and probably non power locks. I dont care (or even know if the crank works because the handle's snapped off), but I just want to take off the motor from the original door and put it on the replacement. What's the easiest way to remove it if you don't care about it? Do you just drill out the rivets? And for installing the power window motor, is that much of a challenge?
Thank you
Vintageracer
Jan 10, 2020 05:33 PM
anesthes
Mar 10, 2016 10:35 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
3rdgenparts
Aug 8, 2015 07:09 PM
