For anyone that has changed out gauges to ones with different mileage.
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
First of all, is there any way that I can set the odometer to my mileage before I put it in the car. I doubt this is possible. So, can I get some kind of official document or something saying that I am getting the gauges replaced at x miles to say y miles. Because right now i have around 78k on an 85 mph cluster. And I just bought a 145 mph cluster with mileage in the 90ks. So how can I prove that I did the swap when I did it? Thanks a lot.
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
It comes apart real easy and is real easy to set to your original mileage. When you take it apart and play with it, you will see why so many people went to jail for "rolling em back"!
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Originally posted by onebinky
Get an old speedo cable and hook it up to a power drill. Only spin it forward though, if you go reverse there is a good chance you will mess up the gears.
this is actually a very good idea, its what i would do
You will have to spin it 80K miles to get close to the correct mileage. 80,000miles/145 mph=551.724 hours to spin it with a drill. Double the speed, 275.862 HOURS. And something will probably break in the speedo spinning at 290mph for 275 hours. I did mine by taking it apart and rolling the odo 10 or 12 years ago, took 5 or 10 minutes. You do the math.
Car: 1987 Camaro IROC-Z
Engine: LB9
Originally posted by Apeiron
Even easier is to just swap the odometer rolls between the two speedo heads.
when i went o the 115 speedo from my 85, i just swaped out the number rolls, 1 clip, be careful and in 5 mnutes your set. Trending Topics
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
I need to reset mine 'cause the original odometer was broken. Got a new (used) Speedo, but how do you get at the number rolls? Looks like you need to take the needle off? How do I do that without breaking it?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't have to take the needle off, just remove the screws holding the face on and you'll have enough room to tilt the face to get the numbers out.
Ghettobird52
Jul 5, 2024 11:18 PM
NBrehm
Aug 25, 2015 11:49 PM
