Hatch pull-down drain battery
Car: '86 IROC-Z
Engine: LG4 305-4BBL
After rebuilding my hatch pull-down (thanks Lon), my battery had a small leak, draining over a few days. I realized when i replaced the unit, it sat low in the car. When it pulled the hatch down the sensing switch did not engage. The motor stopped spinning but I assume it was still drawing current. I have since fixed the hatch and jumped the car, charging the battery. It seems fine now.
Does it make sense if the rear hatch sensor does not tripp even though the motor does not spin it would still draw current?
Re: Hatch pull-down drain battery
Car: 87 GTA
Engine: tpi 350
This site is awesome. I have a draining battery. All I had to do was search "battery drain". There I found several "hatch pull-down battery drain threads", and bingo! That's it. Took like 5 minutes to find the probelm thanks to you. You guys are the best.
1Aauto
Sponsored Vendors
Sep 23, 2015 01:09 PM
