Ground Effects Pushed Out
Old Aug 24, 2005 | 10:20 PM
92F-bird_5spd's Avatar
Car: 1992 Firebird
Engine: 305 TBI
Transmission: T-5 w/ Hurst Shifter
I used a regular jack to lift my car the other day, and I felt the car kinda "slip" a little when I was lifting it. At the time I didn't think anything of it, but when I was washing my car today, I noticed that I now have a Slight gap between my passenger door and the ground effects/ front quater. When I looked under the car, the little tab thing where you're supposed to lift the car from, bent and now sits flat pointing out towards the quater. I can't see what's above it, but if I bend this back out, do you think the fender and quater will shift back in, or is there stuff higher up that may have been effected too? It's not really a big deal, nothing's rubbing or anything, it's just I don't like the new little 3/4" gap back towards the door.
Old Aug 24, 2005 | 10:35 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Your not supposed to jack there at all.. I think the stock jack can work there, but I've still seen stock jacks bend the tab.. Bending it back should get it pretty close.
Kevin D.
Old Aug 24, 2005 | 11:29 PM
Car: 1992 Firebird
Engine: 305 TBI
alright, it's good to hear that bending it back should help it, but exactly where are you supposed to jack it from?
Old Aug 25, 2005 | 12:51 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i jack my car up using the k-member, rear differential, or sub-frame connectors work also. I bent my tab one using the stock jack in the jacking location according to the instructions but not bad enough to push out of my GFX
Old Aug 25, 2005 | 11:04 AM
BlackMagic's Avatar
Car: 1986 Firebird
The privious owner of ym car jacked it up with a regular floor jack in that location and flattened both side, and pushed up the fenders. Just last week, doing body work and preping for the paint, i straightened back out and the fender popped back
Old Aug 25, 2005 | 01:18 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
hell, my car was lifted up on a lift once (before i bought it) and it bent that area.. and but my fenders! can only tell on the driver's one and i have to replace that one anyone.. so i have some work on those tabs
Old Aug 25, 2005 | 06:14 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
on my passenger side fender stuck out about 3/4 on an inch, bening the tab made it about less than a 1/4 inch...not perfect but a hell of a lot better than it was.
Old Aug 25, 2005 | 07:26 PM
Stevo's Avatar
Car: Pair of 92 Z28s
both my sides bent to hell from people who where uneduated on how to set a car on a lift or use a jack...eh not everyone knew the first time they jacked up a car so its ok...
I wanna bend them straight again but havent had any luck.
Old Aug 25, 2005 | 07:39 PM
shr00m's Avatar
If it's bent onto the head of the bolt, you can use a wrench and back the bolt out. Since the head can't go into the body, it will force the tab down enough to get some lock pliers on.
If it's bent on the back side of the bolt, it can't be that flat against the body. You should be able to get a screw driver or pry bar in there enough to get some lock pliers on.
Once you get the pliers on (get the ones that have a large clamping area), you should just be able to pull it where it needs to go.
Kevin D.
KCG
Jun 24, 2020 04:33 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
billybob6110
Sep 23, 2015 01:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
