Split rear seats into a car without them?
Old Aug 25, 2005 | 10:09 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
What do the split rear seat cars have that the solid rear seat cars do not? I know there is that pole thing on the trans tunnel; which I hope we can cut off and re-weld, but do the single rear seat cars have the boss for the latch peg on the driver's side?
Old Aug 25, 2005 | 10:16 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Everything else is the same cept for the trans tunnel pole thing you mentioned.
Old Aug 25, 2005 | 10:19 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
So cars with the single rear seat have the threaded hole for the other latch bolt?
Old Aug 25, 2005 | 10:26 AM
Engine: SBC, LS-x
I think it's in there. I am not 100% sure. Think you just have to drill the hole in the plastic.
Old Aug 26, 2005 | 12:41 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
I did a one peice to split 50/50 rear seat swap. One peice cars don't have the nessessary brackets to add a 50/50 seat from the factory. The center pivot hinge needs to be welded onto the driveshaft tunnel and the latch bracket and cage nut needs to be welded to the drivers side inner wheel house.
The pivot hinge on the tunnel is pretty easy. It just goes between to ribs stamped into the metal.
The latch bracket is a little tricky. Its best to set everything up and then mark its placement before welding everything in.
On the backside of the interior plastic there are two round "supports" that go around the hole for the seat back latch. You can use some cardboard to make a template off the passengers side to put the hole location on the drivers side interior panel.
Old Aug 26, 2005 | 07:54 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
My 89 Firebird has the drivers side seat peg and no split rears. My 85 camaro didn't have the drivers side peg. And that trans tunnel bracket is just 2 small rivets to drill out, its an easy swap.
Old Aug 26, 2005 | 08:16 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I know I need this piece (pivot on trans tunnel), but the other part sounds hard!
This is a pic of the doner car:
Old Aug 26, 2005 | 08:22 AM
Car: 86 T/A
Engine: HSR 355
Check your car, you may have the peg on both sides. If so its rather easy. Also, I meant 4 rivets, not 2. Either way- you know what that piece looks like.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
z28addict8490
Aug 7, 2015 08:48 PM
